BIGGEST TIRES to run on OEM coupe 18's?
Old Mar 25, 2009 | 04:37 PM
Krispyklene's Avatar
what are the biggest set of tires i can run on the 18's? i have a 04 coupe dropped on 350z s-techs... i want to run meatier tires all around for my summer set up... any input on sizes?
Old Mar 25, 2009 | 09:17 PM
JuicedAthletics's Avatar
I ran 255/40 255/45 and 265/40. I preferred the 255/45 best of all. Best blend of performance and ride comfort. The 265/40 bulged a little too much and the 255/40 was a little stiffer and shorter sidewall than stock.
Old Mar 26, 2009 | 07:04 PM
SO JUICED? if i run 245/45/18 in the front if i'm dropped will i be rubbing?
Old Mar 27, 2009 | 02:43 AM
ZIG35's Avatar
KrispyKlean... though I can't provide the answer you're looking for, I could provide you info on where to go for this... Gdup35Sedan. Hit him up, he is totally knowledgeable on this kind of thing and very helpful fellow member. Nice guy!
Good Luck!!!
Old Mar 27, 2009 | 02:58 AM
redlude97's Avatar
There is a good chance it will rub since it is over an inch taller than stock. Horrible size to run. Go with 245/40/18 instead in the front
Old Mar 27, 2009 | 02:57 PM
Sorry. I thought you were talking about the rear tires only. I ran 235's and 245/40 in the front. I am dropped on Tanabe's and there is no rubbing.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
mushu
Jul 15, 2015 03:55 PM
