Which rims should I get?
Old Apr 1, 2009 | 05:38 PM
fino's Avatar
I have narrowed my rim choices down to two and not sure which I want.
I based my decision on the look and budget (budget mostly as I am getting married)
The first choice was TSW Vairano 19x8 f 19x9.5 r (not sure what tire size or offset to get)
The second choice was Petrol Throttle 19x8 f 19x9.5 r (not sure what offset to get)
I do know that the Petrol come with Vredestein UltraC Sessanta tires that are 245/35/19 and 275/30/19. From a review I have seen on here, they are pretty descent tires.
I am leaning toward the petrol but thought maybe others would chime in.
Thanks for your input in advance
NOTE: MY G is red
Old Apr 1, 2009 | 05:39 PM
O HELLA OEM's Avatar
imho i dont like either
but id go with option 2 if i had to really really chooose
Old Apr 1, 2009 | 05:58 PM
fino's Avatar
Also the sales guy said that he would recommend 275/35/19s on the rear instead of the 30s along with a 20mm offset. Does this sound correct. I do want it flush but not too aggressive to where it would screw anything up. Note this is on the second wheel.
Old Apr 1, 2009 | 06:34 PM
WhosUrBuddiee's Avatar
Both make me throw up a little in my mouth
Old Apr 1, 2009 | 06:54 PM
nghiars's Avatar
i would go with 275/35/19 in the rears and 20mm offset sounds decent for a 9.5"wide rim... i would try to go with a lower offset if possible if you dont mind rolling fenders(assuming you're dropped) Dont know much about the brand Petrol but i've seen many cracked TSWs here on the forum.
Old Apr 1, 2009 | 07:48 PM
eurodre's Avatar
+20 offset on a 9.5 in the rear wont get u to be flush, now if ur g isnt that low.. sure its flush.. but imo its not really flush unless you are pretty low first of all
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
