17" minimum width for 275-40/17
Old Apr 7, 2009 | 12:52 PM
Darqfallen's Avatar
I am just wondering if anyone knows the minimum width of rim that would required to fit this size tire? I know they dont fit on 17x7.
Thanks
Old Apr 7, 2009 | 01:47 PM
redlude97's Avatar
minimum recommended width is 9"
Old Apr 7, 2009 | 03:23 PM
Darqfallen's Avatar
17x9... wow.... where am i going to find that...
Old Apr 7, 2009 | 03:59 PM
redlude97's Avatar
enkei rpf1, 5zigen fnor1c, lots of companies make those sizes
Old Apr 7, 2009 | 04:07 PM
Jeff92se's Avatar
Red Card Crew
Most tires have a pretty standard width requirement.
But if you want to know about your speicific tire, you have to go to the maker's site, look up that tire's spec in the size you need and see what they list as a min/max size.
FYI, I've also seen the same sized tire width have a different wheel width recommendation depending on the aspect ratio
Old Apr 7, 2009 | 04:53 PM
Darqfallen's Avatar
Thank you very much. I found some rims. Will post pics when i get it all installed.
TurTLe*
Sep 29, 2015 01:43 PM
Detailed Image
Sep 14, 2015 07:30 AM
