G35 Vs-xx offset question.
Old Apr 8, 2009 | 01:19 PM
bukrickay's Avatar
ok I'm still trying to learn offset so I had a question for the rims I wanted to get for My g coupe. I got a 03 G35/brembo about to be drop on Tein-s tech and I wanted 19's for it with a nice offset with the works vs-xx rims
what would my fellow g35 buddy recommend? I wanted
what would be a good offset for the aggressive look?
also what tire size would be recommended?
Old Apr 8, 2009 | 04:43 PM
gary c's Avatar
The Works VS-XX wheels are beautiful, offsets should be in the mid 20s. To get just the right offsets for your coupe I'd check with Chris at F1 motorsports....1-818-919-8120. Tire size depends on your offsets and how much you're lowered.
Gary
Old Apr 8, 2009 | 05:20 PM
G Nasty23's Avatar
The most common tires size upgrades on here are 245s in the front
and 275s in the rear. The offest like Gary said should be in the lower 20s.
I just bought Tenzo Type M's with 17 offset in front and 22 offset in the rear.
Ordered Nitto Neo-Gens 245s and 275s to go on them. Good Luck!
Old Apr 8, 2009 | 07:40 PM
eurodre's Avatar
SWEET 2 threads on the same thing!
if you want to know offsets, anyone who knows anything about offsets will tell you that it also depends on the widths. If you are pretty low you will need a different combination of width and offsets to be flush
For being pretty low on a 9.5 (front) I found you need about an offset of 10 or less and
10.5 in the rear you can do like a 15 or so and it keeps going up from there
Old Apr 8, 2009 | 09:00 PM
bukrickay's Avatar
Thanks would that be a neg or pos offset?
Old Apr 8, 2009 | 09:39 PM
eurodre's Avatar
uhm.. positive
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
