Wheel Spacer! What size without rubbing ?
Old Apr 9, 2009 | 02:27 AM
DDD*G35's Avatar
Wheels : Volks GT-C 19' 10.5 (REAR Only)
Suspension : Tein Basic Coilovers my suspension is lowered to the max.
Fenders are rolled. So should I go with 15mm, 20mm, or 25mm.
SPC Camber Kit
Offset +24
Thanks for the input.
Old Apr 9, 2009 | 02:28 AM
Calvin's Avatar
Overglorified Altima
what's the offset?
if you're lowered to the max, then you've also probably got some camber? unless you've got a camber kit. what are your camber settings?
Old Apr 9, 2009 | 02:41 AM
DDD*G35's Avatar
I have SPC Cambet Kit but I dont know what the settings are......
Old Apr 9, 2009 | 03:02 AM
V35_Gcoupe's Avatar
this would be a trial and error process, I've been through it myself, started with 5 mm spacers and finally figured out 25s are the way to go. If you're into super aggressive then get 25mm spacers and if it rubs, you can fix it by adjusting your camber.
if you want a safe bet, 15s I suppose.
Old Apr 9, 2009 | 01:50 PM
GReddySetGO's Avatar
Need to know the offset on the rim to know what size spacer to run.
Old Apr 9, 2009 | 02:25 PM
nghiars's Avatar
offsets?
Old Apr 9, 2009 | 03:52 PM
DDD*G35's Avatar
Let me find out
Old Apr 9, 2009 | 05:10 PM
DDD*G35's Avatar
Offset +24
Old Apr 9, 2009 | 05:16 PM
ShanesG's Avatar
go with 15's!
if you're stretched and running more than -2.5 camber you can go more!!!
Old Apr 9, 2009 | 05:19 PM
DDD*G35's Avatar
guys i need your help!!! would a 15mm spacer sit flush on some 19' 10.5 +24 with rolled fenders?
Old Apr 9, 2009 | 05:22 PM
ShanesG's Avatar
?????need more info
camber ?
Stretch??
trying to help.....
Old Apr 9, 2009 | 05:25 PM
DDD*G35's Avatar
tire size is 285/35 no camber
Old Apr 9, 2009 | 05:29 PM
ShanesG's Avatar
ooo then scratch that, maybe 10's!
http://www.workwheelsusa.com/gallery...et=14&photo=22
10.5 +0 running around -2.5 camber and alot of stretch
best way, go out of a angled driveway so the tire/wheel goes up into the fender then measure that gap and order accordingly!!
Old Apr 9, 2009 | 09:56 PM
DDD*G35's Avatar
i got the 15mm spacers and they rubbed a little and i rolled my fenders all they way! it looks sick *** hell...thanks for the help!!!
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Detailed Image
Jul 24, 2015 12:31 PM
