Negative Camber After Mounting 19s??
Old Jul 5, 2004 | 12:30 AM
GG35's Avatar
My rear tires are noticeably tilting in now after mounting 19s...is this normal?
i'm at stock height
Old Jul 5, 2004 | 12:37 AM
Meatshackle's Avatar
Deep Sea Moderator
Re: Negative Camber After Mounting 19s??
I had the same problem. Get an alignment to get you back into specs. I was at about 2.5 in the rear, factory specs are 1.0 to 2.0.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old Jul 5, 2004 | 12:51 AM
GG35's Avatar
will this cause my rear tires to wear prematurely?
Old Jul 5, 2004 | 01:04 AM
Dsskyline's Avatar
maybe if you let it go for to long. I just lowered mine on 19's and I need a alignment bad. I have to get a camber kit first tho. Check out my rear camber in this pic. I heard that you should always get a alignment after going up in size in wheels the contact patch is different. (wider)
Old Jul 5, 2004 | 01:32 AM
Eurog35's Avatar
i just dropped my car on tein s-techs, but i heard most ppl compain about the rear cambering more than the front? how is this possible if the front is dropped lower than the rears? wouldnt the front camber more since its dropped lower?
dsskyline, how low is your drop, and are you on springs or coilovers?
Old Jul 5, 2004 | 03:11 AM
Dsskyline's Avatar
I have a 1.5 drop on Tanabe DF210 springs. I posted early with pics of my drop. If you noticed before you dropped your ride your rears already had a slight negative camber. I think dropping it makes it more negative, you really can't tell the fronts unless you slam it to the ground. Just what I think I could be wrong.
Old Jul 5, 2004 | 10:49 AM
Deep Sea Moderator
Your tires will definitely wear quicker. Spend $70 or so on the alignment and get as close to -1.0 as you can. Unless you plan on autocrossing. Otherwise you're going to eat up those rear tires fast.
Russ
Black 6MT Coupe
Jax, FL
Old Jul 5, 2004 | 11:48 AM
GG35's Avatar
should i just wait till i lower it and get one or do it now?damn, now i'm afraid if i do lower it with h techs, i would need a camber kit.
Old Jul 5, 2004 | 12:05 PM
Dsskyline's Avatar
I don't think you need a camber kit with the h-tech springs the drop is less than 1in. If you are getting them soon (within 1 month ) wait until then. You will need to get a alignment again once you change your springs if you get one now.
Old Jul 5, 2004 | 12:27 PM
JED's Avatar
JED
Hey, timely thread for me! I just went to 19s and after only a few hunderd miles I can see the contact patch on the rears is definitely biased to the inner part of the tire. It's the same on the fronts. Guess an alignment is in my immediate future. Thanks to all for your comments.
John
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Claudiu
Sep 26, 2015 01:04 PM
