Tire help
Tire help
I've recently decided to buy a set of new wheels, and I'm pretty sure I'm going to go with the Linea Corse Lemans. I've never heard of them before, but I wanted something that looked similar to a BBS wheel, just not as much money. I believe a set is around $1,100. Anyway, I'm just making sure that these wheels will fit on a G35 coupe, and I'm also wondering what tire size(s) I should be looking at. The wheel specs are as follows:
18x8.5 all-around
5x120 bolt pattern
35mm offset
I would like to go with Hankook tires just because I've had them in the past, and they tend to run a little cheaper than others. Here's a picture of a G35 with these wheels:
Thanks!
Matt
18x8.5 all-around
5x120 bolt pattern
35mm offset
Thanks!
Matt
So how could the G35 in the picture have them?
The wheel specs you are referring to are for our E36 BMW applications.
Luckily, we do offer these wheels in fitments for the 350Z/G35 Coupe. The following fitments are available (same wheels pictured on the white G35 in the first post)
Front - 19x8.5 +15
Rear - 19x10 +20
You can view more info regarding these wheels here
https://g35driver.com/forums/wheels-...g35-coupe.html
-Dan
Front - 19x8.5 +15
Rear - 19x10 +20
-Dan
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
FS[Canada]: G-Line 18" Black w/Chrome Lip with Tires + TPMS
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
