Wheels wobble with spacers on
Old Jun 4, 2009 | 12:50 PM
LBC77's Avatar
Ok here my problem I've used two different sets of spacers on the rear ichiba v2 15 mills and kics 10 mills both with built in studs...and both times the rear wheeels wobble and my studs are fine my wheels aren't bent and I'm using the proper hub rings anyone have ideas...btw my wheel specs are
Volk gtf
Front 19 by 9.5 +17
rear 19 by 10.5 +24
Old Jun 4, 2009 | 01:10 PM
xx7sephiroth7xx's Avatar
G
Did you tighten the spacers to the hub first using the original studs on the hub?
Old Jun 4, 2009 | 01:20 PM
G35Papa's Avatar
You might want to check the OEM studs again. Even if one is slightly bent the wheel will wobble
Old Jun 4, 2009 | 01:37 PM
redlude97's Avatar
are you sure there is enough space between the lug holes for the extra length of the OEM studs that stick past the spacer? This would prevent the wheel from mating properly with the spacer and cause the wobbling
Old Jun 4, 2009 | 01:46 PM
WILLIE BEANS's Avatar
Debris in between ??
Old Jun 4, 2009 | 06:29 PM
LBC77's Avatar
Ok thanx guys I don't think the wheel is sitting flush I'm going to double check
Old Jun 5, 2009 | 02:39 PM
Skyline_Coupe's Avatar
Could be a broken stud if you saw it wobble when driving.
If not, tighten everything down. Make sure you don't overtorque the spacers on.
Old Jun 5, 2009 | 09:15 PM
eurodre's Avatar
lol ok am i the first to read that title and think.. why make a thread?
i mean if the wheels wobble.. there is virtually ONE solution.. you tighten them more (obviously not over tighten)
Old Jun 6, 2009 | 03:28 AM
Triple8Sol's Avatar
Maybe it's the toe settings?
jsimonk
Dec 22, 2023 03:49 PM
tphan
Aug 31, 2015 10:45 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
