BMW M6 Rims On A IP G35 Coupe! SICK!!
Old Jun 4, 2009 | 06:12 PM
O HELLA OEM's Avatar
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Vb4V9B1WoCw&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Vb4V9B1WoCw&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Jun 4, 2009 | 06:16 PM
HenryLee's Avatar
I think they M6 replica's b/c i know they sell them in different bolt patterns. M6 OEM factory rims only come in 19's. SO those have to be the replica 20s. Case solved. It's made by the company MIRO, I believe.
Old Jun 4, 2009 | 08:15 PM
WhosUrBuddiee's Avatar
Originally Posted by O HELLA OEM
then how did he get these rims to fit?
Already said how. They are not M6 wheels.
Old Jun 4, 2009 | 08:35 PM
xXHotelCrazyXx's Avatar
Damn, hawtness!
Old Jun 4, 2009 | 08:37 PM
dvsmeth0dz's Avatar
i wonder how they got these to fit.
Old Jun 4, 2009 | 08:39 PM
^7 series rims..
haha looks ok
Old Jun 4, 2009 | 08:46 PM
nikkaitsme's Avatar
that is sick!!!!!!! would look sick on a black G
Old Jun 4, 2009 | 09:04 PM
Deezflip's Avatar
you CAN make them fit...regardless if the bmw has lug bolts instead of lug nuts and has nothing to do with the bolt or lug pattern distant, using a spacer adapter going from 5x114.3 to 5x120 conversion will work. With the G's ability for aggressive offsets, you can put spacers of pretty thick sizes and will still clear the fender, even BMW offsets. Maybe and just maybe from this site....
http://www.wheeladapter.com/wheel_adapters.php
if they don't, someone with access to a machine shop or friends in a similar business can easily fabricate one.
Old Jun 4, 2009 | 09:11 PM
^i knew it!
thanks for clearing it up
i knew you could use wheel adapters
i thought i was crazy
Old Jun 4, 2009 | 09:23 PM
Deezflip's Avatar
Yeah i'm just surprise that it's not readily available, I've seen 4-lug to 5 lug spacer conversion, even other 5 lug bolt pattern to other 5 lug bolt pattern, but haven't seen conversions to 120.
But i'm sure with the right bribery and cash, you can get any machinist to fabricate one of high quality. With that said, I'm not all that certain about those wheels in the video though, it's still a possibility that they are replicas. I just wouldn't say that it's impossible.
Old Jun 4, 2009 | 09:30 PM
Invalid_User's Avatar
only looks good because its slammed and pretty good offsets
Old Jun 4, 2009 | 09:31 PM
intense660's Avatar
rofl ppl have made wheel adapters for a billion years esp on vdubs
its possible
Old Jun 4, 2009 | 09:33 PM
Does anyone know the Specs of OEM wheels of the M6?
Old Jun 4, 2009 | 09:37 PM
Deezflip's Avatar
i thought that they were miro's too..but the site only has 5x120 for that design
http://www.mirowheels.com/346.html
Old Jun 4, 2009 | 09:55 PM
  #30
Deezflip's Avatar
Front 8.5J 19" Offset ET:12
Rear 9.5J 19" Offset ET:17
http://www.bimmerfest.com/forums/sho...d.php?t=110715
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
