Gorilla Flush Mount Valve Stems
Does anyone have these installed or experience with these? I'm thinking about picking up a set of these to ensure my new BBK calipers clear. Thanks!
http://www.brandsport.com/grla-vs407c.html
Nah... the stems come with a filler tube adapter.. so basically when you need to check or inflate your tires you attached the this tube to each stem... yeah I know sounds like PITA to do it for every tire.. and your SOL of you lose that filler tube as well..
These are for my DPE's. The existing valve stems are pretty long and are located inside, behind the spokes. They barely clear the BBK template I used to check for clearance. I was gonna have my shop replace them with shorties when I came across the flush mounts... I'll give them a try and I'll let you guys know how it works out!
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
