07 Z 18s VIBRATES HARD @ 60
Old Jul 27, 2009 | 11:41 PM
TotalledCL's Avatar
Exclamation 07 Z 18s VIBRATES HARD @ 60
hey guys, just switched back from a aftermarket 19 to 07 Z 5 spoke 18s.. after driving above 40-50 all the way up, the car vibrates BADLY.. is it because i need a spacer since the offset is off or something is wrong with the axle.. thanks guys
Old Jul 27, 2009 | 11:42 PM
TotalledCL's Avatar
i took the aftermarket ring off before i put these OEM wheels back on... does it has anything to do with that?
Old Jul 27, 2009 | 11:54 PM
elayman's Avatar
did you check your torque specs? maybe they weren't seated right when you torqued them (if you even did)
Old Jul 28, 2009 | 11:59 AM
waijai's Avatar
i.love.gold
If there was no apparent problem before you put the 350Z 18's on there, then it's the new wheels. Check for bends, they might need balancing too.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
BradMD_96
Oct 6, 2015 09:31 AM
