Tire Pressure Light
Old Aug 3, 2009 | 02:37 AM
ANSmith120's Avatar
Unhappy Tire Pressure Light
The tire pressure light is on in my 2006 G35x. I check the tire pressure on all four tires and they are all even and within the suggested level. I don't know what triggered the light to turn on! But now the light won't go out. Is there a way to reset it? Is this a common problem?
Thanks!
Old Aug 3, 2009 | 04:30 PM
jookyshank's Avatar
I haz hugz to givez
Have you changed your valve stem caps? The TPMS can have difficulty unless you use the oem style plastic caps, least that is what happened to me. The dealership actually thought they would be nice and put on polished caps (without my knowledge) and I had the same issue with the light until I went back in and an Infiniti Tech saw it and swapped back. Poof...light works fine now
jsimonk
Dec 22, 2023 03:49 PM
Fireman07603
Aug 9, 2015 06:00 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
