Crappy Tires, what should I do?
Old Aug 11, 2009 | 12:05 AM
jd4321's Avatar
Angry Crappy Tires, what should I do?
I usual do some research on this site or theg35spot.com or tirerack before I make a purchase. But I got a blown tire and I had to replace both rear tires. I went to a small local place and got Hercules WR-1 Raptis tires. The said they were better than the tires that I had(Nankings). Um I don't think so. These are the worst tires ever.
I took a small curve on dry pavement and the slip signal started coming on. In the rain they are even worse. The VDC goes crazy when I take any type of curve. I just got these tires. I can't replace them now. What should I do? Will they get better with time?
Old Aug 11, 2009 | 11:09 AM
Q45tech's Avatar
Obviously you don't care about your life but others may be able to sue you or your heirs!
Old Aug 11, 2009 | 01:05 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Not the best idea to mix/match brands on the car, especially in wet conditions. That's probably the majority of the issue. I would get something the same all around have it be two more of those or four of something else.
Old Aug 11, 2009 | 06:30 PM
jd4321's Avatar
Thanks for the reply. When I got the car it had different tires all around already. The problem is that they needed to be changed at different times. I have Falkens that are pretty good on the front its these rear tires that are killing me now. I recently replaced the front ones and I just got the back ones so I can't spend any more $$$ on tires.
I got a suggestion to let some air out of the rear tires to see if they grip better. Does that work?
I need other options besides replaces the back tires.
Old Aug 11, 2009 | 06:38 PM
PLATINUM SPONSOR
Dropping the pressure won't really make it handle better but rather increase ride a little. Typically people will increase pressure to provide better steering response. I'm not sure where the pressures are now, but if you play with them, don't drop below the pressure recommended in the door/owners manual, don't exceed the tires max psi listed on the sidewall.
Old Aug 11, 2009 | 06:49 PM
jd4321's Avatar
Thumbs up
Thanks, I will keep that in mind.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
