opinions
Old Aug 19, 2009 | 04:46 PM
Heist.'s Avatar
Thumbs up opinions
So I need new tires. I am going to get 235/40-18 due to they are cheap. I currently have z springs and struts. Should I get 20/25 mm spacers on all 4. Would this fit and look decent ? or be pushed out way to far ? Thanks
or does anyone have a better Idea on spacers like 15 20 or what? please help!
Just want aggressive and clean.
CURRENT SETUP:
thanks!
Old Aug 24, 2009 | 01:58 PM
Heist.'s Avatar
SOMEONE PLEASE INPUT! going to get spacers soon and idk what to get !
Old Aug 24, 2009 | 02:23 PM
LightsOut's Avatar
SIETESG
what are your offsets?
your running same tire size all around?
do you want to roll your fenders?
flat black sedan... that looks clean.
Old Aug 24, 2009 | 02:27 PM
Heist.'s Avatar
Current wheel setup on all 4:
League WKR-1
18X8 5-114.3 40BRS
Here is the tire I am going to be running on all 4:
http://www.americastire.com/dtcs/fin...=CAOINT&cs=235
and yeah I would be willing if it is as easy as the DIY with the PVC pipe to roll the fenders.
hope that helps! And thanks
Old Aug 24, 2009 | 02:40 PM
LightsOut's Avatar
SIETESG
dont use the pipe.. get a pro roll.
bad thing, I dont know much about sedan aggressive offsets.
Old Aug 24, 2009 | 02:42 PM
LightsOut's Avatar
SIETESG
taking a look at your pics i say a 10mm front and back should make you flush.
Old Aug 24, 2009 | 02:43 PM
Heist.'s Avatar
ahaha yeah. Well I have done a lot of reading but nothing really is that helpful this is the only thread that had a decent amount of information. I think I am just going to sack up and get 20 in the front and 25 in the back and roll the fenders in time.
https://g35driver.com/forums/wheels-...-question.html
Old Aug 24, 2009 | 02:44 PM
Heist.'s Avatar
Really? I feel like it needs to be brought out a lot more. Maybe your right, I am struggling with my decision on these
Old Aug 24, 2009 | 02:45 PM
LightsOut's Avatar
SIETESG
be patient many sedan guys here could help you.
Old Aug 24, 2009 | 02:47 PM
Heist.'s Avatar
I would if I didn't have to get them today I have work the rest of the week
Old Aug 24, 2009 | 02:49 PM
LightsOut's Avatar
SIETESG
pm..
Shane or TycoRc
tyco has a sedan and knows all about flushness.
Shane is the KING to flushness he could help you out.. but he has a coupe
Old Aug 24, 2009 | 03:06 PM
Heist.'s Avatar
pm..
Shane or TycoRc
Thanks for the help. I will ask.
Old Aug 24, 2009 | 03:26 PM
ShanesG's Avatar
Based on those pics, i'd go 10mm all around, but what tires are in those pictures???
Also you WILL need to get your fenders rolled or cut, it looks like you are pretty close as is and a spacer will def. make yu rub, especially since you want an aggressive stance.
Old Aug 24, 2009 | 03:32 PM
Heist.'s Avatar
235/50/18 I believe. I am just going 10 smaller save 300$
Yeah I figured I am just going to go with 10/15 my front is rolled. Just get the back done. Thanks.
Old Aug 24, 2009 | 03:56 PM
The Stimulation's Avatar
I'd definitely lower the car some more and then do the spacers, unless you're okay with the current ride height. If you plan on dropping the car soon then I'd hold off on spacers, because depending on your drop you may need larger spacers.
Going with a 40 sidewall, although cheaper, will increase the gap you have, so I would consider going lower.
