WTF is on the front hub????
I just tried to test fit my new wheels and for the life of me i couldn't figure out why they wouldn't fit. Then i realized that there is another little stud in between the studs that hold on the wheel on. At the end of it there is a gold nut 12mm. Im guessing it is the inlet to grease the hub?? How should i make the wheels fit if this on the hub? obviously it has to be removed. How do you do it?
You can unscrew that puppy and remove it all together, it will not drain all your grease out, it has no other purpose.
Cajuncowboy
Jun 21, 2021 09:47 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
