axis 19'' Mesh 2 for my G coupe?
Old Aug 2, 2004 | 10:04 PM
hojinn's Avatar
I am now considering to get new rims on my g but i found i needed to care about too many things. Since this is my first try, I unfortunately do not have much idea. Plz give me help!!!
Question #1
Is axis 19'' Mesh 2 okay considering gear ratio and everything?
Question#2
Can i still drive my g with 19'' Mesh 2 in winter? ( I live in MI)
Question#3
If the answers for # 1,2 are no, what kind of wheels are good for my G? would you guys recommend some good ones?
Plz help me!!!
Old Aug 2, 2004 | 10:50 PM
biscotti's Avatar
Re: axis 19'' Mesh 2 for my G coupe?
19 inch wheels are not going to affect VDC and ABS as long as you keep the over all diameter of the tires similar to stock. Most people are running 245/35/19 for the front and 275/35/19 for the rears. As for winter, I do not think that you will be able to find 19 inch winter tires. Keep the original wheels and put winter rubber on them. There are lots of choices for 19 inch wheels, depends on how much you want to spend. Forged wheels are generally stronger and lighter than cast wheels, but much more expensive.
Old Aug 2, 2004 | 11:15 PM
RyanBeppu's Avatar
I have just purchased this exact setup. Unfortunately I have yet to put the rims/tires on my ride yet. I'm waiting for a set of H&R Sport Springs to arrive first. Drop me a PM for updates or pics in the near future.
Good luck.
Ryan B
Old Aug 3, 2004 | 02:10 PM
DAWB's Avatar
hello, the axis mesh 2 is a beautiful rim however the dimension of the wheel and its offset will work but not perfectly the perfect rim is a 19x8.5 at least and a 19x9.5 to a 10 4 inch lips will be attained in the rear and a 2 inch in the front 245/35/19 and 275/35/19 will work beautifully . keep in mind that the width of the rim affects the way the tire looks on it to narrow of a rim on a wide tire looks bad and too narrow of a tire on a wide rim will also look bad try and find a mean . SEE YA
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
raeyang
Jul 25, 2015 11:25 AM
Kal Hamm
Jul 24, 2015 08:55 AM
