have problems with new wheels
Old Aug 26, 2009 | 09:42 PM
rob05G35's Avatar
i got a set of after market wheels on my 05 and when you get above 60 the skip , abs , and traction control lights come on and when you stop at a red light or stop sign n hit the brake the pedal goes down an slips alittle like theres air in the lines. But when i put the stock wheels back on the front everythings normal again. What could it be?
Old Aug 27, 2009 | 11:58 AM
jwrape's Avatar
Sounds like the abs System doesn't like those wheels.
Old Aug 27, 2009 | 02:58 PM
LightsOut's Avatar
SIETESG
what are your wheel specs including tires?
Old Aug 27, 2009 | 03:02 PM
Deezflip's Avatar
chances are, you probably have the wrong staggered tire sizes on them.
Old Aug 27, 2009 | 03:38 PM
redlude97's Avatar
+1.
Old Aug 27, 2009 | 10:50 PM
rob05G35's Avatar
they are 18x8.5 i believe with 255/40 on the back n 235/35 up front . the new wheels are still on the back with stock on front with no problems
Old Aug 27, 2009 | 10:52 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
you need a 245/40 or 225/45 tire up front. 235/35/18 is waaaaaay too skinny.
-GP-
Old Aug 28, 2009 | 12:31 AM
Deezflip's Avatar
-GP-
+1, you're getting a 6.0% staggered diameter size from those tires you have now.
The OEM 18 staggered diameters for the coupe is 2.7% difference from front to rear. I think +/- 2% from 2.7% should be ok(i forget), but your way beyond that and that's what kicks in the VDC.
Old Aug 28, 2009 | 02:32 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Yup tire diameter issue.
Old Aug 28, 2009 | 05:02 PM
rob05G35's Avatar
ok the thing throwin me off is the tires are the same size as the stock ones that were on it . Could it be the sensors on the stock wheels doin it?
Old Aug 28, 2009 | 05:04 PM
PLATINUM SPONSOR
Don't see how as they only read pressure.
Old Aug 30, 2009 | 12:07 PM
rob05G35's Avatar
ok thanks everyone will see what happens with bigger tires
MsFitFern
Aug 9, 2015 02:58 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
sailfish250
Jul 30, 2015 11:39 AM
