cracks on tires?
Old Aug 27, 2009 | 09:31 AM
cmesidewayz's Avatar
cracks on tires?
today i noticed that on my tire i had crack marks where it came in contact with the road on the sidewall.
how serious is that?
by the way this is the only tire that has a slow leak.
Old Aug 27, 2009 | 09:33 AM
jwrape's Avatar
As you already know or you wouldn't have asked, it's time to replace them.
Tires have AT MOST a 5 year life span, but if they start to dry out and crack you are running the risk of a blow out at high speeds. There is a date on your side wall to tell you how old the tire is.
Old Aug 28, 2009 | 02:34 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Serious enough they should be replaced. Means the oil has dried out of the tire and it's dry rotting. Running on borrowed time.
Old Aug 29, 2009 | 09:12 PM
Q45tech's Avatar
Michelin provided test to US government showing extreme durability problems after 20,000 miles [lesser and lower quality tires] not they will fail just the likelyhood increases exponentially.
Why do you think oem spec fast wearing tires [besides wet braking and handling tests for magazines] because they want to make sure you have to replace tires while warranty is still in force.
Old Aug 31, 2009 | 09:29 AM
yeah they are about four years old with 19,000 miles on them. orgininal tires.
il put some new ones on.
oem or any suggestions?
Old Aug 31, 2009 | 09:47 AM
GreenGoblin's Avatar
The goblin resurrection
I would suggest some Nitto Invo I loved mine.
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
derres
Aug 28, 2015 03:27 PM
rping
Jul 26, 2015 09:53 PM
