SNAP CRACKLE POP SWAYS SUCK
Old Aug 3, 2004 | 08:48 AM
SixFive's Avatar
What happened? Left the office yesterday and on the way home my car sounded like a Chryser K car - 1979 or so..every time I hit anything uneven in the road. All I had to do was accelrate once and I could hear shiit moaning and rattling under there..>wtf
ALigment is still perfect, the handling isn't gone, the exhaust is not the problem and the sways I had my mechanic install last week are firmly attached still.
Maybe the bushings are shot or weren't attached in the front properly???
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Aug 3, 2004 | 10:48 AM
al503's Avatar
Re: SNAP CRACKLE POP SWAYS SUCK
were the bushings greased?
Old Aug 3, 2004 | 12:31 PM
SixFive's Avatar
Yes they were. This isn't squeaking - it's banging and crunching as though you are draggin a cat or a pipe that grinds when you change directions. It was from a loose front connection...
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Aug 3, 2004 | 04:46 PM
bkchang79's Avatar
Go check the bolts on your sway bars. Especially the nut that attaches to the end of the sway bar.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
http://www.sounddomain.com/id/bkchang79
Old Aug 5, 2004 | 07:18 AM
cato's Avatar
SouthernComfort Moderator
Sixfive,
You are making me think my decision on buying the Stillen
sway bars was right. Now I'm getting worried of my installation
coming up this weekend. Please keep us informed of your
solution this. If you can advise me of what NOT to do, great!
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS muffler,
14 wire Grounding kit, 350Z duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals
Old Aug 6, 2004 | 02:43 PM
zazaracing's Avatar
Team Transport Member
send them back and buy the HOTCHKIS!
03 6MT Coupe Blk/Blk> Injen CAI, Hotchkis adj Sway Bars, Test Pipes< "Nt G R8D" Aj
Old Aug 6, 2004 | 10:04 PM
SixFive's Avatar
thats what they are ..and today my boys put some lube on there and all is perfect. I love these sways again
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Aug 6, 2004 | 11:19 PM
zimbo's Avatar
Lube is always good for what ails ya.
--Steve
Old Aug 7, 2004 | 05:56 PM
6speedG35sedan's Avatar
I have the Eibach sways and the same thing happened. I took them to the shop that installed them and they lubed them and tightened everything down after a week and they have been silent ever since then.
Base 6MT Silver sedan
Stillen Exhaust
Stillen CAI
Eibach Pro Kit
Eibach Sway Bars
Kaaz LSD
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
