Newbie with a question about wheel spacers
Old Sep 1, 2009 | 12:24 AM
Kellen's Avatar
From: From California to Carolina, Im all over the place
First off, IVe got an 04 g AT. Im looking at a set of wheels, f -18x8 r - 18x9.5. Will I need spacers and if so, what brand/sizes. Thanks for the info.
Old Sep 1, 2009 | 12:30 AM
CandlestickPark's Avatar
ill Sedan
Need to know the offsets of the wheels to determine whether or not spacers will be needed. Also what kind of look are you going for, aggressive with wide tires or aggressive with stretched tires. What is your current ride height? What kind of camber are you looking to run? Sorry for so many questions but these are all variables that you need to consider.
Also, do you have a coupe or a sedan?
You'll get a lot of help if you post your questions here: https://g35driver.com/forums/wheels-...-ask-here.html
Old Sep 1, 2009 | 12:34 AM
Kellen's Avatar
Sorry, had to re type the post and left out all the important info. Ride height is down about 1.3 inches, offset on the wheels is +25, going for a aggressive with wide tires look.
Old Sep 1, 2009 | 12:35 AM
Kellen's Avatar
coupe
Old Sep 2, 2009 | 01:26 PM
reverse's Avatar
20mm front, 20mm or 25mm back. not sure on the tires, but i would assume that a stretched look would look a lil funny on that setup.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
