Another Fitment question
Old Sep 28, 2009 | 07:46 PM
DopeFresh's Avatar
Hey guys
I recently purchased 19x8.5 F 19x/10 R for my 05 g35 coupe. (Offset +15 f/+20 r)
i was wondering If it would fit on my car or if it's too aggressive?
Also I was thinkin about 245/35/19 front 275/35/19 rear? What would be the best choice?
Thank G drivers!
Old Sep 28, 2009 | 07:52 PM
tragedycat's Avatar
No problems whatsoever, you're good to go. Just for reference there are people on this board running 9.5/10.5+ with offsets in the single digits, nothing is too aggressive, just a matter of how much money, work, and headache you're willing to put into your suspension setup.
Old Sep 28, 2009 | 08:35 PM
DopeFresh's Avatar
would I give any stresss to my suspension? I was thinking about lowering the car slightly with eibach prokit or tanabe, or tein springs just to reduce finger gaps.
Old Sep 28, 2009 | 08:55 PM
tragedycat's Avatar
Lowering your car will stress your suspension, period. There's no way around it. Just make sure to do your research when buying springs, you say you want to drop your car 'slightly' but Tanabe springs generally give a pretty big drop no matter which version you go with.
If you want to eliminate your wheel gap, be prepared to buy front and rear camber kits to get your car back into alignment.
Old Sep 29, 2009 | 08:57 AM
idrive_MD's Avatar
Hey guys
Thank G drivers!
You are more than safe with those specs, Rotas or Linea Corse wheels I guess? Tire specs seem fine too. As for springs, if you want something thats subtle but effective, just get the Tein 350Z H-Tech springs or the RSR springs, the Espelir Springs (just make sure they're the 350Z-spec for each). They'll lower you from roughly .8 to 1.1-inch. The spring thread can clear that all up for you. At worst you may need a rear camber toe kit.
Spring/Shock Faq
Old Oct 1, 2009 | 03:39 PM
Inyong1988's Avatar
Shouldn't have problem there.
Old Oct 1, 2009 | 10:18 PM
SuperStezzyG's Avatar
no problems and u dont need to roll your fenders... I had the same set up 19x8.5 +15 and 19x10 +20 linea corse dyna 245/35 and 275/35.
Old Oct 1, 2009 | 10:29 PM
DopeFresh's Avatar
^ great to know!
Any pics of how it sits? Were you lowered?
Did you have any rubbing issues front or back?
Old Oct 5, 2009 | 05:52 PM
DopeFresh's Avatar
bump.
Old Oct 6, 2009 | 01:01 PM
DopeFresh's Avatar
Anyone knows the tires size I need? I'm leaning towards to 245/35/19 275/30/19
Old Oct 29, 2009 | 02:43 AM
repin_LB's Avatar
i believe 245/35 and 275/35 the most common tires for the 9.5/10.5 series, so should work fine. get some pix up when you get these wheels thrown on the car
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
