Front Tire Wearing Inside
Old Oct 3, 2009 | 10:28 AM
TurK's Avatar
Exclamation Front Tire Wearing Inside
I have my G lowered with Z S-tech Springs...It sits where I want, but already had to change the rear tires... and now the front tires in the inside are shot...I have camber kit in the rear but the front does not have anything.
The only part thats real bad in the front is the inside area... the rest looks fairly good.
What can I do to prevent early tire wear in the front? What parts do I need to adjust it correctly?
Also any camber adjustment recommendations? I think the ppl I got it done through put the car in the stock settings but the car is lowered so I know the settings should be different...
Thanks!
Old Oct 3, 2009 | 11:38 AM
Dark_'s Avatar
You need upper control arms; there are kits out there that allow you to adjust the camber.
Check out the vender sale section for deals on the arms.
Old Oct 3, 2009 | 11:40 AM
PAIXAO's Avatar
You definitely need a front camber kit.
Old Oct 31, 2009 | 11:14 PM
TurK's Avatar
I believe I have the SPC rear camber....would you guys recommend getting the front SPC as well?
Old Oct 31, 2009 | 11:56 PM
parhamm1's Avatar
SPC or SPL front camber kit would do you a world of good.
Old Nov 3, 2009 | 05:37 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
+1 camber is your friend or foe.
Old Nov 3, 2009 | 05:43 PM
The Stimulation's Avatar
I'd first verify if your toe is in spec.....then get it in spec and see how much your camber is off in the front. If too much, then seek out upper A arms. Cusco, SPC/SPL would do the job.
Old Nov 7, 2009 | 09:40 AM
TurK's Avatar
Well they said they did all they could with the stock parts... So does that still leave any room for toe play or do I still need to get a camber kit?
Old Nov 11, 2009 | 12:25 PM
fishmd's Avatar
You can still get toe adjustment done and this will reduce the inner wear. The other thing that can be done to give you a little more life to your tires is to flip them. Not to rotate the tires, but to actually remove the tires from the wheel and flip them so the worn side is on the outside. OF course, you can only do this if the inner tire is not totally shot. Then, I would not recommend it.
Old Nov 16, 2009 | 10:19 AM
st350z's Avatar
Making hard/sharp corner turns at high speeds will definitely wear out the inside of your front tires. That is the main issue that causes inside front tire wear.
That might be your problem so slow down on turns & cornering!
Old Nov 19, 2009 | 11:26 PM
Osa713's Avatar
I have the same problem as well. But i have and 05 w/stock sports suspension. and oem 19's. Should i get a front camber kit as well or just find a more reputable alignment shop? I got an alignment five months ago and bought new tires but now im back in the same boat.
And the alignment shop could not get my camber out of the negative.
Old Jan 5, 2010 | 07:54 PM
TurK's Avatar
Lol, this is an addiction of mine...
So my front right tire gave out today.. had to drive 50miles home with the spare.(sucked)
Who sells T1R for the best price?
Old Jan 5, 2010 | 08:01 PM
Neu Era's Avatar
Adjustable front control arms will do the trick, then get an alignment. They couldn't get mine perfectly aligned, but its close enough.
Old Jan 5, 2010 | 11:25 PM
bocatrip's Avatar
The front inside tires of the 03-07 G35 Coupes will wear prematurely with the standard suspension setup. Once lowered, it's more extensive. A camber kit is absolutely necessary once lowering our cars.
Old Jan 16, 2010 | 04:19 AM
TurK's Avatar
which camber kit would you guys recommend ??
Thanks!
