255/45/17 tire on a 17x8 wheel
Old Aug 13, 2004 | 01:29 AM
dklau33's Avatar
I know leadfoot has that combination and he says it is just fine and has no sidewall flex issues. Looked up several 255/45/17 tires on the manufacturers website and they seem to all have a recommended rim width range of 8"-9" for a 255 tire. My question is if 8" is the minimum recommended width for a 255 tire, will it be okay regarding sidewall flex with just normal tire pressure of 30-33 psi for everyday driving? Will it be okay with a higher tire pressure of lets say 38-40 psi for track days and auto-xing? I'm planning on getting some 17x8 wheels with 255/45/17 Kumho MX tires in the somewhat near future. I will be doing occassional road races and autox's. Just want to make sure I won't have sidewall flex issues because the width of the rim is too narrow even though it is within the recommended range. Thanks.
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway/ '03 350Z Shocks and Springs
Old Aug 13, 2004 | 01:24 PM
dklau33's Avatar
Re: 255/45/17 tire on a 17x8 wheel
Anyone?
Old Aug 17, 2004 | 10:07 AM
3point5SE_Auto's Avatar
you will have a little bulging, but it will look good. Plus it will protect your rims abit too. If tirerack has it in their recommended rim width than that is all you need. You can usually fit one size outside that rim width too.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
Old Aug 17, 2004 | 12:06 PM
lowrider's Avatar
No Problem. This is the smallest recommended rim width for this size tire. Since it's withen Manufacturers specifications, all will be well.
Lou
Old Aug 17, 2004 | 12:17 PM
dklau33's Avatar
Right, the 8" is the minimum but I believe 8.5" is the recommended. So in terms of going road racing, will the 255 tire on the 8" rim be okay? Or will I have to raise the tire pressure up a bit to keep the sidewall stiff and prevent it from rolling over on the turns? Thanks again.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
