Toe Bolt
Old Aug 19, 2004 | 12:42 PM
FIRESTARTER's Avatar
Toe Bolt
I lowerd my car with Tien S-Tech spring and it's time for me to buy the camber arms, I just want to know if I need to get the Toe Bolt too to bring my rear Toe to spec. Any suggestion will help thanks.
2004 | 6MTs | Diamond Graphite
Old Aug 19, 2004 | 05:41 PM
Re: Toe Bolt
Anyone???
Old Aug 19, 2004 | 06:58 PM
al503's Avatar
Re: Toe Bolt
Some cars will stay within spec when lowered while others will not even with the same springs/drop. The only way you can tell is to get the springs installed and get an alignment. You may be able to adjust them back into spec (probably close to max spec though) or you may not. I went with the SPC camber bars and toe bolts. I think I got them for just over $200 shipped. Run a search on them under SPC.
Old Sep 8, 2004 | 09:11 PM
GPhanatic's Avatar
Re: Toe Bolt
you can get the SPC kit here www.iapdirect.com
<P ID="edit"><FONT class="small"><EM>Edited by GPhanatic on 09/08/04 06:34 PM.</EM></FONT></P>
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
