what size tires for rear wheels?
Old Nov 18, 2009 | 11:15 PM
rob40wilson03's Avatar
i currently have the stock size tires on the back of my car, but i need new ones and am looking to upsize a little bit
i now have 245/35/19s in the front... what size should I get for the rears that won't upset VDC etc?
thanks!
Old Nov 18, 2009 | 11:58 PM
money042's Avatar
try this:
http://www.1010tires.com/tiresizecalculator.asp
Old Nov 19, 2009 | 07:18 AM
so according to this, it looks like 255/40/19 will work.... am i correct?
Old Nov 19, 2009 | 07:41 AM
HenryLee's Avatar
yea you can run a 255/40/19 easily.
Old Nov 19, 2009 | 07:54 AM
JOKER's Avatar
CLUB MODERATOR
I doet..............easily.
Old Nov 19, 2009 | 09:11 AM
money042's Avatar
yes, it would work.
Old Nov 21, 2009 | 02:06 PM
Blue Dream's Avatar
I drove ttrank's car solo
You compared a 245/40 to a 255/40 in your chart. If change the front to the 245/35 you are currently running the diameter difference becomes 4.74% which exceeds the recommended max difference of 3%.
Could be a problem.
Old Nov 21, 2009 | 05:27 PM
eurodre's Avatar
205/30
Old Nov 21, 2009 | 05:31 PM
kennymo's Avatar
whats the width of the rim? is it the 19x8.5?
if so i ran a 275 on my rims in the rear on my 20s that were 8.5 wide with no problems
Old Nov 23, 2009 | 10:23 PM
Could be a problem.
wait, so with the tire size calculator, i need to compare the front tire size i currently have with the rear tire size that i WANT??
what i did was put in the stock rear size (i currently have the stock rear size) and tried to find a wider size for the rears that would work
did i use the calculator wrong?
EDIT:
all i want to do is find a larger size for the rears that will work with my 245/35/19 that i have in the front
Old Nov 23, 2009 | 10:26 PM
Originally Posted by eurodre
205/30
haha umm i wanna upsize
Old Nov 23, 2009 | 10:27 PM
eurodre's Avatar
405/40
Old Nov 23, 2009 | 10:52 PM
thanks for being no help, 2 times in a row
Old Nov 24, 2009 | 09:11 PM
can anybody clear this up for me please?
Old Nov 24, 2009 | 09:39 PM
stinkytofu89's Avatar
i've ran 255/40/19 on the rears with no problems
