Stock Supension Question
Old Aug 22, 2004 | 11:44 AM
Thor20's Avatar
I did a search before posting and came up with nothing.
I was at the dealer yesterday and was informed by one of the saleman that the Tire and Wheel package (T&W) was not necessary for the everyday driver. He said that the T&W package was more for the enthusiaist.
Is there a huge difference between the sport and non-sport T&W packages as far as performance and everyday drivering are concerned?
Thanks.
Old Aug 22, 2004 | 12:36 PM
Gsedan35's Avatar
Re: Stock Supension Question
Are you asking about the performance difference between the tires used on each suspension or the performance difference between each suspnsion. As you've worded it, your asking about the difference between tires, not the suspension's. Could you clarify.
I do have comment's as performane difference's between the two suspensions. You'll get comment's that they don't really differ, which I totally do not agree with,.......at all. As a exclusive user of max performance tires, I'll take the fifth on all season rubber.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Aug 22, 2004 | 03:28 PM
Thor20's Avatar
Sorry about the confusion.
I was refering to the performance differences between the two supensions.
Old Aug 22, 2004 | 05:16 PM
Q45tech's Avatar
Tires are much more significant than suspension. Suspension just primarily effects steering feel and body roll whereas tires can generate real improved numbers independent of driver skill.
Tires show the greatest variantion in warm wet braking distances and wet slalom.
A 5-10% difference would be the greatest.
If you are not asking the car for the nth peak of designed in performance non directional tires and small plain wheel sizes will be more economical...............tire and wheel life/balance, and replacements are significant operating cost items.
Differences can be over a thousand or 2 dollars per year or more. A set of tires every year and new wheels every 3-4.
Think carefully.
Old Aug 22, 2004 | 08:44 PM
Thor20's Avatar
How about the limited slip that comes with the sport package is that something I should concern myself we having or not, keeping in mind that this will be my daily driver?
Thanks.
Old Aug 23, 2004 | 06:57 AM
Q45tech's Avatar
Limited slip is a very very very good addition! I've had it on all my [9] cars since 1971 [Chevy station wagon], 4 Chevy sedans thru 1985, 300zx, Pathfinder, Q45.
Never would own a car without it! So much better than traction control alone [which uses brakes].
The only thing I still like about GM is everything is optional if you can learn the secret codes.
The Nissan VLSD is tolerable once you understand that it requires 1 full spin of the tire to start working and it works equally well on deceleration [braking and just engine retardation] unlike gear mechanical versions.
Old Aug 23, 2004 | 03:21 PM
SixFive's Avatar
Aren't the poeple upgrading existing non-LSD cars to have LSD saying that it's a waste of time and money?
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Aug 23, 2004 | 04:27 PM
dklau33's Avatar
In terms of pure performance, yes it would be a waste of money. For about the same amount of money one could get an aftermarket LSD like the Nismo or the Kaaz. Those clutch type LSD's are superior in performance as they will actually prevent slip whereas the viscous LSDs will kick in only after the wheels have started slipping. Also the clutch types usually will handle much more torque loads than the viscous units will.
But if all out performance isn't needed and the person does not track the car then the oem viscous LSD would work just fine. Lot less maintenance on the unit and isn't intrusive as a clutch type.
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway/ '03 350Z Shocks and Springs
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
