New rims for my coupe!! Help suggestions opinions
Old Dec 6, 2009 | 09:26 PM
sachel20025's Avatar
OK SO I BEEN SEARCHING AND CAME ACCORSS THESE>>
http://cgi.ebay.com/ebaymotors/20-IN...Q5fAccessories
WAT DO U GUYS THINK???
MY CAR IS NOT LOWERED AND NOT PLANNING ON DOING IT DONT HAVE THE MONEY RIGHT NOW???
WHAT TIRE COMBO SHOULD I GO WITH FOR FRONT AND BACK???
ANY OTHER GOOD RIMS OUT THERE SUGGESTIONS????
ONLY HAVE A 1300 BUDGET FOR BOTH RIMS AND TIRES
Old Dec 6, 2009 | 09:31 PM
Calvin's Avatar
Overglorified Altima
Edit, didn't see it includes tires.
Hard to suggest wheels for your car when we don't even know what it looks like. I'm guessing it's otherwise stock, but what color is it?
Definitely consider Five Axis...
https://g35driver.com/forums/wheels-...me-wheels.html
Old Dec 6, 2009 | 10:30 PM
^^ its a black 05 coupe 6 speed manual
and yes its pretty much stock
well the rims i posted also includes the 4 tires
Old Dec 6, 2009 | 11:43 PM
jonathan0702's Avatar
8.5inch all around isn't usuallly what people go for. More like 8.5 in front and 9.5 in back, especially for 20s
Old Dec 7, 2009 | 12:03 AM
kennymo's Avatar
i think they look clean as ****.
Old Dec 7, 2009 | 12:11 PM
^^ yea they look pretty tight dont they
Old Dec 7, 2009 | 03:07 PM
nghiars's Avatar
+40 offset = no bueno for coupes
Old Dec 7, 2009 | 06:14 PM
Silencer_0's Avatar
I think you should drop your car first, and then save up for the wheels. A nice drop will make your car look good with any wheels, and springs aren't that expensive. Aftermarket wheels at stock height is gonna look weird IMO. But good luck!
Also, with those widths and offsets, you're gonna need to buy wheels spacers.
Old Dec 8, 2009 | 12:51 PM
wats the best offset for the coupes??
Old Dec 8, 2009 | 01:42 PM
Silencer_0's Avatar
That really depends on how aggressive you like it, but for the wheels you want to buy, I'd say +10 or +15. So you'd need 25-30mm spacers.
Old Dec 9, 2009 | 12:33 PM
what do you guys think about these ones???
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Dec 10, 2009 | 08:58 AM
money042's Avatar
First, realize our coupes have staggered wheels. Rear is larger than front. This is good for RWD cars for better acceleration, launching, etc. There are coupes out there who run all four the same size (there are a ton of threads around here discussing the topic, but I'm keeping my coupe staggered).
My opinion is, if you're not going to lower the car, stay away from plus size wheels. They'll make you're wheel gap look bigger. If you're not going to lower, get 18". You'll good with 19" depending on the style of wheel. But if you go 20", your G will look like a lifted, off-roading monster truck. BTW, do you have OEM 18" or 19" Rays?
It's already been mentioned, but keep an eye out for the offset. For the G, you'll want something +35 or less (actually, in this case, the lower the number, the greater the offset, i think). The lower the offset, the more the wheels will stick out from the wheel well (which is a good thing, at least in my opinion), nothing lower than +20 to be safe. Unless you want to get spacers. Adding spacers "lowers" your offset. If you get a wheel with +40 and add a 20mm spacer, you're overall offset is not +20.
For tires, make sure you use this:
http://www.1010tires.com/tiresizecalculator.asp
Plug in your stock tire size up top and put in your prospective tire size(s) below. Anything greater than a 3% difference, NO GO! Tire size will somewhat depend on your wheels selection.
I hope that helps.
also, "Good" rims would be Volks, Work, HRE, etc. You spent "good" money on your infiniti, expect to spend good money on "good" wheels Of course, as the saying goes, you get what you pay for.
Old Dec 10, 2009 | 11:53 PM
^^^thank you!!! very good info.
Yea the car came with the 19" rays
Old Dec 11, 2009 | 03:02 PM
SilentAttack's Avatar
Step UP get some VOLKS
Ill sell you mine
Old Dec 11, 2009 | 06:36 PM
Higrev's Avatar
mmmmmmmmmmmmmm
