G37 rims on a G35 coupe?
Old Dec 17, 2009 | 02:21 PM
justice76's Avatar
Originally Posted by FlyingLumpia
The g37 wheels will fit on a sedan and does not require a spacer. They wont be that aggressive either. If you look in the sedan section or maybe do a search you will find it.
Hello can you explain what you guys mean by aggressive rims. Sorry Im a noob.
Old Dec 17, 2009 | 02:58 PM
miltoda's Avatar
Aggressive usually means the wheel almost sits flush with the fender.
Old Dec 20, 2009 | 05:04 PM
bmwdinamo's Avatar
sorry guys, i'm a neanderthal... i'm about to put those on a 04 g35 coupe,,, do i need spacers? what difference does it make? Where can i buy the right ones?
Old Dec 31, 2009 | 09:12 AM
izeroi's Avatar
Well I recently put some G37 wheels on my G35 coupe and it looks really good imo. I'm still not sure if I like them more than my 19" oem rays, but none the less they look good. The look bigger since they don't have the lip like the rays do. Probably the only thing I' am going to do is switch out my 245/40/19 rear tires and get245/35/19's. Since I' am dropped on S-techs there is barely any wheel gap in the front and a little bit in the rear (I rather just make it look even all around). Also I used 20mm spacers in the front and 25mm in the rear and imo that's the right size to go with. You might get away with 25mm in the front but I'm just going to go ahead and stay with 20mm. I'll have some pictures up this weekend after new years and all.
Old Dec 31, 2009 | 09:28 AM
izeroi's Avatar
With spacers it gives your car a more aggresive look. Meaning with spacers your wheels will sit further out. If you don't have spacers they sit further in. I guess just visualize it this way, without spacers your wheels are closer to the center of your car, with spacers they are further away from the center of your car. You can buy spacers in the forsale section of the forum (that's where I purchased mine)
Old Feb 13, 2011 | 08:46 PM
Nice G35!'s Avatar
I have an 05 G35 Coupe. My questions is does it require spacers? I have them on now with out spacers and they are making some what of a rubbing noise, I don't know if its my brakes or something else, I did slam my breaks earlier the night before but idk if that has anything to do with it...Well I'm lost at this point I don't know what to do....
Old Feb 13, 2011 | 08:47 PM
Nice G35!'s Avatar
Btw I am talking about putting G37 rims on a G35
Old Apr 25, 2013 | 09:40 AM
LaCeD562_'s Avatar
I have a question as well what about for the G37s sedan rims wud they fit a regular 2008 journey without having spacers on em????
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
BlackGee35
Jul 23, 2015 01:36 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
vstypicals
Jul 20, 2015 10:55 PM
