Heard of WedsSport Wheels?
Yea those are the ones in the catalog I think.. can't tell for sure cause the pics are small. it looked like there are some steel lugs as well. How does Porsche get away with using aluminum lugs? couldn't you just use some anti seize compound?
I'll be staying away from aluminum lugs per intgr8r's advice even though I haven't tracked my car before, it is a possibility and don't want to buy twice
I think I'll look used
I've just heard about this from guys at the track that had it happen.
also;
NEVER use anti-seize on lug nuts, torque specs are for dry threads.
Because it acts as lubricant, you will over torque the nuts when installing.
So 80lbs with lube might be more like 100+ dry.
^Yep ima get those soon. Elay i got my project Mu's for $160 i believe, they are exactly the same as kics but they had a more gunmetal coat which is why i got them over the kics!
can you PM me where you got them?
