g35x struts??
Old Aug 27, 2004 | 08:08 AM
rayron's Avatar
g35x struts??
anyone know where i can get aftermarket struts for the awd sedan? does anyone make them?
thanks,
aaron
Old Aug 27, 2004 | 11:25 PM
biscotti's Avatar
Re: g35x struts??
Not sure if the struts in the G35X are the same as in the G35 sedan and coupe. You could see if the new Tokico D-Spec shocks would fit.
Old Aug 28, 2004 | 04:30 PM
av8r's Avatar
Re: g35x struts??
I'm pretty sure they would fit. I think the difference is the G35x is set up to handle the added weight. You should try and give Tokico a call. Their number can be found at: www.tokicogasshocks.com
04' Sedan 6MT Silver/Graphite/Premium/Aero/HuperOptik/XM
Z-Tube / Stillen- Sways, Airbox & Grounding Kit
19x8.5/9.5 Hiros / S-03s 245/40 & 275/35zr19
Coupe Suspension
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Nov 1, 2015 03:26 PM
Claudiu
Sep 26, 2015 01:04 PM
