coupe *flush* offset
Old Jan 16, 2010 | 08:46 AM
CandlestickPark's Avatar
ill Sedan
^Got any pics of these wheels on your car.
Old Jan 16, 2010 | 08:48 AM
GreenGoblin's Avatar
The goblin resurrection
why not measure? Tape measure and calculator you could figure out exactly the offset you need
Old Jan 16, 2010 | 10:46 AM
kennymo's Avatar
What exactly do I measure. And I will take a picture when I get home from work.
Old Jan 16, 2010 | 10:49 AM
kennymo's Avatar
I understand backspacing more than offset. Is there a way to convert the measurement that 8 get?
Old Jan 16, 2010 | 11:25 AM
erklep's Avatar
if the wheels u have now, sat flush on his coupe... they have to be around the 0-+15 mark. if you want to know for sure, pop a wheel off and look inside the spokes. it should be stamped in there
Old Jan 16, 2010 | 11:38 AM
The Stimulation's Avatar
Not possible as that would require a fender roll and pull. Maybe the +15 is the closest but I think that would poke too much without a pull.
When I had coupe 19's, 19x8.5 +33 was almost flush. I'd say as someone suggested that since they were flush on a coupe and poking on your sedan, it's probably a +20 to +25 and someone mentioned a +15 to +25 already I believe.
There are guys running about +20 but they did a fender roll and I believe a pull. Now that I think about it more I'm going to say high teens to low 20's for the offset...again, it all depends on the drop that you have and the coupe had.
It's been expressed a couple times but put it this way..See the pic that was posted in the 2nd post? It sits pretty straight. Lower it 1" and it's going to tuck. Now, what if the coupe you got the wheels from was sitting higher? What if it was lower? You're talking about quite a difference if it was sitting 1" lower or 1" higher. That's 2" and quite a difference so nobody is going to be able to tell or give you a good rough estimate without knowing the drop of that coupe or even knowing the drop of your car to figure out an estimate.
Old Jan 16, 2010 | 11:45 AM
erklep's Avatar
totally possible. my t1s are 9.5/10.5 +5 all around and they fit with no fender work. im pretty slammed, tucking tire. granted i have a little stretch but i could easily throw a 5-10mm spacer under them and still not need a pull
Old Jan 16, 2010 | 12:57 PM
Frankieg35's Avatar
What are u talking about you have your front and rears rolled.. Last i checked thats classified as fender work..lol I think your loosing your mind erik still thinking about that busted coilover lol
Old Jan 16, 2010 | 01:20 PM
kennymo's Avatar
The coupe they came off had no drop at all completely stock.
Old Jan 16, 2010 | 01:37 PM
erklep's Avatar
hardly a roll. and its def no pull. not to mention, i still have plenty of room to go. you saw it first hand
Old Jan 16, 2010 | 01:38 PM
HenryLee's Avatar
I thought I answered this. If it was flush on a coupe with no drop and factory chamber most likely the rims are 10in width w/ +10 to +15 offset. Thats why it sticks out your sedan fenders 3/4 inch
Old Jan 16, 2010 | 01:52 PM
Frankieg35's Avatar
Yeah that is true.. im just breaking *****.. It is classified as fender work even though mild.. lol
Old Jan 16, 2010 | 02:26 PM
nghiars's Avatar
but it only pokes on his sedan about 3/4 inch. If it's flush on his coupe at stock height and pokes about 3/4 in, my guess would be an offset of about +20... maybe as high as +24.
edit: +1 on donpisto's breakdown
Old Jan 16, 2010 | 03:30 PM
On a sedan its very impossible, trust me I know.
Old Jan 16, 2010 | 03:34 PM
  #30
Can't be. I had -3.8 degrees of camber and with a 10.5 +0 I was sticking out about an inch with a little pull. That equates roughly to a 10.0 -7, so it's gotta be higher than the +10 to +15. The 10.5 +0 was sitting flush on a coupe with a drop (cookie monster's old setup) and no camber arms. He was low, raise it back to OEM height and he's gonna be poking out quite a bit.
