Bolt Size?
Old Sep 3, 2004 | 06:21 PM
groovy4's Avatar
Bolt Size?
Is 5 x 114.3 the correct bolt pattern for the G35C?
Old Sep 3, 2004 | 06:49 PM
R2 V35's Avatar
Re: Bolt Size?
Yes it is! [img]/w3timages/icons/smile.gif[/img]
"Is simplicity best or simply the easiest"
Old Sep 3, 2004 | 07:11 PM
groovy4's Avatar
Re: Bolt Size?
Thanks Mang!
Old Oct 22, 2004 | 04:46 PM
TINMAN's Avatar
Re: Bolt Size?
dennis.it's 114.3mm not 143.3mm like you keep thinking.
Old Oct 23, 2004 | 06:23 PM
GZire's Avatar
Re: Bolt Size?
Like TINMAN is saying it's 143.3 mm versus 114.3 mm (what we have). 29 mm translates to a 1.15 inch difference.
GZire's Avatar
Re: Bolt Size?
Like TINMAN is saying it's 143.3 mm versus 114.3 mm (what we have). 29 mm translates to a 1.14 inch difference.
Old Nov 21, 2004 | 10:41 PM
dennis_said's Avatar
Re: Bolt Size?
Tagging on late
But my question is... would 5x143 work? Or does it HAVE to be 143.3?
Also, I am assuming 5 means the number of bolts, what is the measurement of the 143.3?
Thanks!
If you have some 19s that you want to sell... let me know
Old Nov 22, 2004 | 12:09 AM
GZire's Avatar
Re: Bolt Size?
No 5x143 will not work. Here's a link to an explaination of what the numbers mean.:
http://www.tirerack.com/wheels/tech/boltpatt.htm
Old Nov 22, 2004 | 01:59 AM
Re: Bolt Size?
Ah thanks GZire,
Hmm the diameter in mm... 143.3 and 143 don't seem to have that much of a difference then, I'm figuring that the stems can slide through the bolt holes no?
Or is it really that precise of a fit? I ask because these Axis Milano rims that I am interested in come in 5x143 only
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
