Another Wheel Fitment Question....
those specs will stick out almost an inch past fender edge in the front - and nearly 1.5" in the rear...
even with fenders rolled and even pulled, you will need to run quite a bit of negative camber... a lot actually (considering of course you are lowered).
For reference, here is a similar setup to what you are trying to run. Owner is dz n.u.t.z.
19 x 9.5 +23 245/35
19 x 10.5+23 275/30
Camber in the rear is -3.5, not sure on the front. He is very low on coils. Rear fenders are pulled. Front fenders rolled and slightly pulled.
Since you are an X you should find tire sizes that are almost identical to each other, like I suggested in another post you can go with 225/40, 255/35. Tires will be slightly stretched.
19 x 9.5 +23 245/35
19 x 10.5+23 275/30
Good info on that. Thanks Marcus. I was wondering if this would look foolish.
19 x 9.5 +23 245/35
19 x 10.5+23 275/30
19 x 9.5 +23 245/35
19 x 10.5+23 275/30
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
joedaddy1
Jul 28, 2015 02:58 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
