Same size rims/tires on front/back on a G35 coupe?
Old Mar 15, 2010 | 02:30 AM
wonton1017's Avatar
I am new to modding cars, at the moment i am dying to get some black rims with a polished silver trim around, so i found some 5zigen rims with the following specs:
Front and rear:
19 x 8.5
235/35/19
Offset is +38mm
5 x 114.3mm
I did a research and found this: (stock 06 19" rims)
WHEEL/TIRE SPECS:
FRONT
Size: 19" x 8"
Bolt Pattern: 5 x 114.3mm
Offset: +33mm
Center Bore: 66.1mm
Stock Tire Size: 225/45/19
REAR
Size: 19" x 8.5"
Offset: +30mm
Center Bore: 66.1mm
Stock Tire Size: 245/40/19
So im not sure whether or not it's a good idea to have identically sized rims/tires on my RWD car, just my logic telling me that because g35 is RWD, it came with larger rear rims and tires.
Not sure if i really like the design yet as i am interested in something with thicker and less spokes (but not too less spokes, somewhat close to the stock 2006 g35 coupe 19" rims). I chose this one right now because it's cheap and local.
Old Mar 15, 2010 | 02:41 AM
HenryLee's Avatar
I would not get those rims. Bad offsets and width. I bet sedan guys wouldnt want those offsets.
wonton1017's Avatar
Thanks for the advice
What width and offset should i be looking for?
Old Mar 15, 2010 | 02:54 AM
techi13's Avatar
i agree with ^^^
if i'm getting aftermarket wheels..at min. i would get 9" +17 fronts and 10"+23 rears
in my opinion, looks best when you get the wheels flush as possible to the outside fenders
Old Mar 15, 2010 | 03:25 PM
wonton1017's Avatar
At minimum as in +17 and +23 or greater, or at minimum as in +17 and +23 or less?
Old Mar 15, 2010 | 04:58 PM
Silencer_0's Avatar
I think he means +17/+23 or less (single digits). Personally, I'd only get low single digit offsets.
Jusseth
Sep 13, 2020 12:25 PM
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
