widest aftermarket wheels
Old Mar 16, 2010 | 09:07 PM
imGdup's Avatar
Question widest aftermarket wheels
What are the widest size aftermarket wheels and tires I can put on a stock 04coupe safely with no rubbing thx
Old Mar 16, 2010 | 09:14 PM
340tog35's Avatar
18x10 - 20x10 I think
Old Mar 16, 2010 | 09:31 PM
4DGS's Avatar
At stock height?
Old Mar 16, 2010 | 09:46 PM
Deezflip's Avatar
i think someone had some 315s tires here recently? I'm guessing his rim width was 12? Nevertheless, with the correct offset(a rather weak one I suppose), you can make something that wide, fit....maybe even without a fender roll.
I've had 285 on 10.5 without a fender roll, no rubbing, a mild 26 offset, and more room to spare...but I was on stock suspension at that time.
Old Mar 16, 2010 | 09:48 PM
imGdup's Avatar
Originally Posted by 4DGS
At stock height?
yup
Old Mar 16, 2010 | 10:08 PM
Sylvan lake V35's Avatar
I run 19x12 with 305mm tires on the rear. I am lowered and fenders rolled no rubbing. I run minimal negative camber -1.15 for traction purposes with too much negative camber they run the risk of rubbing on the inside.
Old Mar 16, 2010 | 10:14 PM
4DGS's Avatar
At stock you can run almost anything.
^car is a killer
G35VSHNG37
Oct 25, 2015 08:43 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
BlackGee35
Jul 23, 2015 01:36 PM
