Wheel Spacer is it SAFE?
Old Apr 5, 2010 | 11:45 AM
Xet's Avatar
Xet
Originally Posted by bina12834
i have stock 19's on stock rubber and i plan on lowering with the 350z h-tech's and getting 25mm all around or 25/30....i know im going to have to get my fenders rolled.
you won't rub with the 25mm if you are running oem tire sizes, you will rub if you up to 255/40/19 in the rears. not sure about the 30mm but I would guess you would rub...
Old Apr 5, 2010 | 11:46 AM
bina12834's Avatar
even with the 350z h-tech drop i wont rub? i thought that no matter what if you were dropped and got spacers, you would need to fender roll?
Old Apr 5, 2010 | 12:12 PM
Xet's Avatar
Xet
yup even with z h-techs, that's my current setup. I ran 25mm all around dropped on the z h-techs for at close to a year with no problems. But then I changed my rear tires to the larger size and they started to rub.
Old Apr 5, 2010 | 12:13 PM
bina12834's Avatar
hmmm...good to know....thanks!!
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
