Honda S2000
Old Mar 22, 2010 | 03:21 AM
Malfetano's Avatar
Exclamation Honda S2000
Will the oem 19" Rays fit well on a ap1 S2K? qq
Old Mar 22, 2010 | 07:44 AM
idrive_MD's Avatar
S2Ks at most came with 17" wheels OEM, 19" wheels often look too big on them. They also have much higher offset range than the G-coupe, so you'd be pushing the limits of the fender lips on the S2K. Shame though, they would probably look good. Oh and you'd need to get hubcentric rings from Nissan to honda size as honda runs a smaller hub bore from what I recall.
Old Mar 22, 2010 | 09:42 AM
welery's Avatar
^what he said. I just came from an S2000.
Old Mar 22, 2010 | 01:39 PM
4DGS's Avatar
Especially if you're going 19 with a +30 offset, that's low and big for an S2k. Lower offsets on smaller wheels are much better for the s2000.
Old Mar 22, 2010 | 04:21 PM
Malfetano's Avatar
thanks for the feedback, I have a great oppertunity to get a set but i wasint sure. I might stick to the ap2 wheels and paint them bronze and flush them on a 1 inch drop, which I dont think I could do with a set of 19" Rays but, the Rays look hella clean in powdercoated Bronze. ... I will coat the AP2 sets in Bronze and sit it on a inch drop with 15mm spacers in the back and 10 in the front. As for tires im not sure yet. But thnx guys .. Ill post pics when proj is done
Old Mar 22, 2010 | 04:30 PM
HellaFly's Avatar
You should take a look at this thread for figuring out what size spacers to use with stock AP2 rims.
http://www.s2ki.com/forums/index.php...ic=668408&st=0
Old Mar 24, 2010 | 09:16 PM
onthe3rdday's Avatar
+48 thru +70ish is what that car needs.
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
maximino
Aug 12, 2015 02:05 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
Cacoepy
Aug 3, 2015 01:09 PM
