Widest tires on stock wheels.
Old Apr 19, 2010 | 11:53 AM
Junkyardspecial's Avatar
I just started autocrossing my 4 door sedan with good results, but Im using a super thing 215 mm tire. I want to go as wide as possible. I was thinking 235 might be logical but I am not quite sure as I have only owned the car for about two weeks. The wheel i have is the 6 spoke on the 2003 model, I NEVER use VDC unless its on ice, so I am not worried about the computer. Also, Any suggestions for light wheels that are still 17inch? Thanks!
Old Apr 20, 2010 | 02:17 PM
03GT35R's Avatar
My 03 Sedan has 5 spoke stock 17" with 235-45-17's all around car sits much better & eliminated some body roll as well..I also have it sitting on Tein S tech springs, it handles the corners great. I as well turn the VDC button off as soon as i start the car..
I have also had 245/40/17 on the rear with 225/45/17's on the front...
These are the specs for the wheels i have...
17" 5 spoke (03-04 Sport)
Front & Rear: 17"x7" (+45mm)
Old Apr 20, 2010 | 02:21 PM
03GT35R's Avatar
Here are your rim specs...
17" 6 spoke (Sedan std)
Old Apr 20, 2010 | 09:44 PM
G35sedan03's Avatar
isn't the 6 spoke rim a 6.5" width? I got the sport pkg on mine so it came with the 5 spoke 17x7. You also have a lot of options for 17" light wheels. Volk, Gramlights, SSR, WEDS Sport, Rota, 5Zigen, Advan, etc. Not sure on your budget though.
Old Apr 22, 2010 | 09:55 AM
dt0r's Avatar
I just got some bridgestone serenity 235/50/17 installed on my 06x with OEM 7 spokes and it is awesome... I see no fitment issues whatsoever... The 235/50 is supposed to keep the speedo/odom the same also
Old Apr 22, 2010 | 01:44 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
+1 on 235/50-17. Will fit fine and good selection in that size.
Old Apr 22, 2010 | 02:18 PM
nghiars's Avatar
These guys got your tire specs covered.
As far as good cheap track wheels... Look into Enkei RPF1's. Light, quality build and inexpensive.
obender66
18 Inch
Mar 13, 2016 12:20 PM
CJay
Aug 1, 2015 03:57 AM
realtalk21
Jul 20, 2015 09:07 AM
