G35 coupe camber and toe?
I have the stock camber and 350z S-tech
My right front tire is wearing out crazy especially inside.
If I get alignment, is it possible to fix the problem?
I heard that g35 coupe camber and toe could be adjusted with the OEM, but just hard to do, so need to pay extra $$.
I sold my car to my friend, so I want to give him my car with alignment done.
You probably need buy some camber arms to correct the camber issue. I can't see you tire but is sounds like you might have a little toe issue on the right side as well. Not sure if you did it or not, but you'll def need an alignment after getting dropped.
I've got SPC in the rears and Ichiba in the front. I like them both but I couldn't get my camber in the front less than 1.7 degrees. But I'm ok with that because my tires seem to be wearing ok. Toe is the biggest killer of tires and a good alignment will fix it.
hope that helps... cheers
I did the alignment and the right front toe was -.45, and now its -.08.
I can feel difference!. Movement is very rapid and steering is easy to control. I was surprised about getting alignment. Very sharp moving in corner..however, I sold my car to my friend lol...I could have done it before I sold my car. I regret it so much..
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
