Rotora or Stoptech Rotors??
Old Sep 29, 2004 | 07:26 PM
GG35's Avatar
which is better or are they the same?should i go with xdrilled and slotted or just slotted?
rotora slotted
rotora slotted and xdrilled
stoptech
Old Sep 30, 2004 | 09:08 AM
Q45tech's Avatar
Re: Rotora or Stoptech Rotors??
Measure the thickness ratio of metal to air space on the vented rotor and compare to total weight [higher the weight the lower the temperature rise] of the rotor from sinking the heat created. The thicker the edge metal the better and yes even 0.1-0.2 mm matters on 9mm thickness, 7 mm ait then repeat of 9mm. Some rotors have thicker inside face than outer.
Internal rotor vent fin design is importantant as is the perfection of balance of the rotor.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
