SF Challenges with wheel spacers
Old Jun 28, 2010 | 09:47 PM
luv2revmyg's Avatar
Hi, I've searched, but couldn't really find the answer I was looking for. I would appreciate the help. Here is my setup: Sf challenges fr 245/35-19 8.5 +21 offset, R 275/30-19 9.5 +23 offset. I also have stance gr+ coilovers with spc front and rear camber kits. What size spacers should I get? Do I have to roll fenders if I go with 15mm spacers in the rear? Will I have any steering issues if I go with 15mm in the front?
Old Jun 28, 2010 | 10:27 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Yes, if you put 15mm spacers in the rear then you will have to roll your fenders.
- Son
Old Jun 29, 2010 | 12:24 AM
luv2revmyg's Avatar
- Son
So the front should be ok? I might just go with 10mm.
Old Jun 29, 2010 | 12:27 AM
XiN's Avatar
XiN
Itasha Coupe
Front should be fine.
Old Jun 29, 2010 | 05:12 PM
reverse's Avatar
I got same setup but @ +5 f/r. I'm running 20mm all the way around / 2' drop. 15mm you will need to roll the rears fenders. 10 you might be able to get away with it. with a 1 in drop i was still cutting rear tires on bumps. the tires are a lil too fat...
Old Jun 29, 2010 | 06:04 PM
luv2revmyg's Avatar
I guess rolling the fenders isn't really a problem so i'll go 15mm all around. What kind of spacers are you running?
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
