20X9 and 20X10
Old Apr 10, 2003 | 08:02 PM
culmination's Avatar
20X9 and 20X10
hello i am planning to order axis s7 mod 20x9 +37mm offset for front(245/35-20).... and 20x10 +47mm offset for rear (275/30-20). by the way i already have a drop on my car with eibach prokit. will i have any problems with rubbing? thank you in advance
Friends don't let friends drive stock
Old Apr 10, 2003 | 10:49 PM
wren57's Avatar
Re: 20X9 and 20X10
Um I do not have my g35... yet... but consider a 2" drop already I would say you are going to have massive rubbing problems if you can even fit those tires in the wheel well, not to mention the sterring issues up front...
Laser Red, Graphite, 6MT due June
Old Apr 11, 2003 | 02:24 AM
Re: 20X9 and 20X10
well reading some other threads in this forum it seems that people with 19x10 are having no problem with any rubbing at all. besides the eibach is only an 1" drop....
Old Apr 11, 2003 | 03:32 AM
DallyCurtis's Avatar
Re: 20X9 and 20X10
what your going to have to do is some measurements...
generally considering the intial ride hide and dropped ride height of 1.1 in relation to the wheel size and tire size thereafter.
20 by 10s will fit in the back the largest tire I have seen is a 285 I believe on a 19 inch rim... (rxeven I believe the guys name is here)
largest 20 was 275 I believe on KKh713's ride....
it is 245/35/20 <Front> 275/35/20 <Rear> ... not sure of the rim width ..
his car is not lowered though...
maybe PM him to find out what the rim width is and if the 1.1 drop will cause you problems
https://g35driver.com/rides/detailride.php?vehId=393
hope this helps and good luck
Old Apr 11, 2003 | 11:03 AM
rajc007's Avatar
Re: 20X9 and 20X10
i should be receiving my 19x8 and 20x10 axis se7en mods today. my car should be here in a couple of weeks so i can let you know if a 2 inch drop will be possible by once i have the wheels on. btw, i'm putting a 285/30/20 on the rear.
also i'm going with a 245 on the 8" in rim so maybe you should think about getting a wider tire for 9" on the front?
03 CB G35 Coupe 6MT
estimated arrival - 5/6/03
Old Apr 11, 2003 | 02:00 PM
damen's Avatar
Re: 20X9 and 20X10
i hope that 19 front and 20 doesn't look bad. i'm going 20 all around.
Old Apr 11, 2003 | 02:07 PM
rajc007's Avatar
Re: 20X9 and 20X10
Here's a pic of that setup on a 350z, i like the way it looks. I think this is the same setup that Axis has on their 350z but with a 20x10.5 on the rear.
03 CB G35 Coupe 6MT
estimated arrival - 5/6/03<P ID="edit"><FONT class="small"><EM>Edited by rajc007 on 04/11/03 11:18 AM.</EM></FONT></P>
Old Apr 11, 2003 | 02:14 PM
rajc007's Avatar
Re: 20X9 and 20X10
couldn't get the pic to work....another try....
03 CB G35 Coupe 6MT
Old Apr 11, 2003 | 02:16 PM
rajc007's Avatar
Re: 20X9 and 20X10
one more, i really like that rear lip...
03 CB G35 Coupe 6MT
Old Apr 11, 2003 | 07:45 PM
gaklid's Avatar
Re: 20X9 and 20X10
Gotta love that! Looks like you could go sit on that lip!
Ivory Pearl/Premium/Xenon/
Old Apr 12, 2003 | 03:34 AM
Re: 20X9 and 20X10
VERY NICE ... I LIKE IT ALOT
HOW MUCH YOU PAYING per rim and tire ... and where do ya live...?
good stuff .
later G
Old Apr 12, 2003 | 02:14 PM
rajc007's Avatar
Re: 20X9 and 20X10
I got Falken tires pretty cheap from onlinetires.com, i think 236/tire on the rear and 181/tire for the fronts.
I'm not sure of the exact per rim price but i got a really good deal from Big_H on this forum, a lot lower than any advertised prices out there. You may want to PM him.
I live in Los Angeles.
03 CB G35 Coupe 6MT
Old Apr 13, 2003 | 04:31 AM
Re: 20X9 and 20X10
I dont really like this picture ... only because I took the rims off the 350 ..and had to strech and resize em and they got all screwed up ...blah blah blah..
the only reason why this is posted is one because its relevant to this and it frustrated the hell outta me...
but whatever
later fella's
Old Apr 15, 2003 | 10:52 AM
frostylfe's Avatar
Re: 20X9 and 20X10
That is soooooooooo HOT!
Old Apr 17, 2003 | 07:04 PM
OvaYahead's Avatar
Re: 20X9 and 20X10
there was that one BS g35coupe that had 19" OZ rims. He has 295's in rear.
Do you remember that add? he was selling them on ebay.
BS G35C 6spd navi/aero/prem
