Think This is stretched enough?
Old Jul 8, 2010 | 07:42 PM
HertzG35's Avatar
About to purchase my tires. (general exclaims uhp!)
i checked rrim tuck and i came up with these sizes.
i just need clerification before i go spend 500 dollars
245.35.20 on my 10 or 10.5 rear. not sure which it is.(long story short. wheels came on car and no specs are stamped on them.)
and 225.35.20 on my 8.5 or 8 front. (same story lol)
you can give me you opinins for both sizes. trying to go flush with my air kitt on stock suspension.
THANKS!
Old Jul 9, 2010 | 12:44 AM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Your rears would be stretched just fine. Just remember that General UHP's stretches are large.
If your front is a 8 or 8.5, that tire size seems like it would be normally run on that tire size.
OEM 19" Rays in the front are 19x8 and I run a 225/40 on them and that's just normal. If its an 8 in the front, run a 215 /35 stretch and you should be good.
Old Jul 9, 2010 | 12:46 AM
I'd run 30 series sidewall
Old Jul 9, 2010 | 12:51 AM
XiN's Avatar
XiN
Itasha Coupe
^^ I'm still kind of new to the fitment, but you don't think that would be too thin, Chris? Not to question your judgement, but just trying to understand as well.
Old Jul 9, 2010 | 02:35 AM
HertzG35's Avatar
but i dont think general makes a 30 sidewall in those sizes?
Old Jul 9, 2010 | 10:21 AM
eurodre's Avatar
you would need to provide the full specs for those wheels cus if you are trying to be FLUSH with "air kit" i would assume you would want to be pretty low.. at which point you need some serious specs
Old Jul 9, 2010 | 01:20 PM
HertzG35's Avatar
very true. but like i said theres no stamps or nothing. would you like to tell me how to find out the specs?
Old Jul 9, 2010 | 02:56 PM
XiN's Avatar
XiN
Itasha Coupe
If you don't know the width of your wheel, that can be easily done by actually measuring it.
As for an offset calculator, you can use this link here.
https://g35driver.com/forums/wheels-...tch-guide.html
Old Jul 9, 2010 | 03:00 PM
eurodre's Avatar
google =
http://www.ehow.com/how_5021837_calc...el-offset.html
basically finding the offset is measuring whole width of rim, divide by two to find the middle then the offset is the difference between were the middle is (calculated) and were it ACTUALLY is
Old Jul 9, 2010 | 03:02 PM
XiN's Avatar
XiN
Itasha Coupe
Dre.. my wheels came in today.
Old Jul 9, 2010 | 03:04 PM
HertzG35's Avatar
mkay but to measure the exact width id need to take off my tire..
Old Jul 9, 2010 | 03:09 PM
HertzG35's Avatar
nice what wheels did you get?
EDIT: oh nvm i see you signature lol Sweet i love t1s
Old Jul 9, 2010 | 03:10 PM
eurodre's Avatar
pics or it didnt happen
measure the rim... the rim.. just take your wheel off your hub
Old Jul 9, 2010 | 03:20 PM
HertzG35's Avatar
lol isnt the actual width of the rim where the tire and the rim meet not the lips? cus i measured the rim from lip to lip but thats not correct. i dont have 11 on the rear and 9 in the front. cus im on 275 and 245 and they are a little big for the rim. the actual rear center is 4 inches in and the fronts are 2.5 inches in. if i had 8 and a 10 that would be an inch difference in the back and 1.5 inch difference in the front.
Old Jul 9, 2010 | 03:26 PM
eurodre's Avatar
dude
http://www.google.com/#hl=en&source=...01d881a5ff002f
