offset question !!
Old Jul 9, 2010 | 02:08 PM
lilvi3tboyzz's Avatar
Exclamation offset question !!
so im getting this set 20x8.5 and 20x10.5 with offset front 32 , back is 30. So i was wondering if the offset is good? or is it bad? or how does it look ? thanks let me know u guys opinion
Old Jul 9, 2010 | 02:26 PM
whoozyadaddy7's Avatar
sedan or coupe? what size tires? It is very weak for coupes. Sedan would sit OK.
Old Jul 9, 2010 | 02:54 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
^^ Exactly what he said.
If you're getting those wheels for your coupe, I'd recommend you pick up some 20mm or 25mm spacers
For my daily driving habits, I would probably go with 20mm all around, to get you at a +12 in the front and +10 in the back, but if you want more poke then go with the 25mm. If you're going to be dropped with those offsets tho, you would need a fender roll in the back in order to clear.
Even if you aren't dropped, the wheels are still going to looked tucked on your car... if its a coupe.
If you got a Sedan, then you should be fine.
Old Jul 9, 2010 | 11:18 PM
sorry i dont know what kind of tires yet, i still new at this. so id appreciate it if yall can sugguest some good looking wheel and some good tires. im Looking for 19 and 20'
Old Jul 9, 2010 | 11:40 PM
EL-EE-ES's Avatar
ok, first we need to know a few things...coupe or sedan? lowered? fender mods? budget?
if you want good looking wheels, volk and work have very nice wheels.
Old Jul 10, 2010 | 01:01 AM
oh sorry, i forgot to mention. mine is a coupe Lowered. planing to rolling fender, budget around 1.5 to 3k
Old Jul 10, 2010 | 01:58 AM
XiN's Avatar
XiN
Itasha Coupe
Next question, are you going for a semi-aggressive or aggressive look?
These factors will determine if you need to run a stretch with some negative camber or not.
Edit: Here is an example of my front set up.
F: 20x9.5 +15 | Yoko S-Drives 245 - 35
Old Jul 10, 2010 | 02:01 PM
definitly aggressive look
hey u have aim? its easy to talk since we both live in houston maybe we could meet up and chill =]
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
