View Poll Results: What should I go with?
*Want to order: 19x9.5 + 0 offset F, 19x10.5 + 0 offset R
53.85%
*Other option: 19x9.5 + 12 offset F, 19x10.5 + 0 offset R
46.15%
Voters: 13. You may not vote on this poll
+12 or +0 offset fronts
Old Sep 6, 2010 | 02:18 AM
alex_b's Avatar
I order my wheels next week. The only thing that scares me is how much camber I will be running b/c I dont want to be going through tires monthly. Also will I have to pull my fenders in the rear or rolling it with strectched be ok? My car is a daily driver. I really want the aggressive look but if I cant go with it w/e.
Old Sep 6, 2010 | 04:32 AM
andrewyfang's Avatar
There's so many +12s/+0s around here. Just go look at pictures of TE37s and ask the OP his offsets if they aren't posted already. I personally would go with 0s. I think tire wear will be fine, won't be too bad.
Old Sep 6, 2010 | 10:28 AM
Deezflip's Avatar
Originally Posted by HomieG35
Here are my +12's getting tested out.
+0's will be sticking out an additional half inch to inch
depending on wheel.
is that +12's on a 10.5 width? I think it's not as aggressive as it seems when you dont have it jacked up. I would stick a second jack on the spring bucket and raise the wheel up for a more accurate test while you dont have the tires on yet.
Old Sep 6, 2010 | 10:37 AM
O HELLA OEM's Avatar
I have+12 te's front/rear
Specs 19x9.5 and 19x10.5
tires , 245/35/19 front / 275/35/19 rear
I have some camber going on but not sure how much. and I needed my rear fenders rolled
Old Sep 6, 2010 | 10:44 AM
Deezflip's Avatar
^there you go, very nice example of +12 on 10.5, keep in mind that he's running 275/35 tires. If you go narrower on the tires, I'm not exactly sure which size, 245, 255 or even 265 maybe....you'll be able to fit the +0 probably with roughly the same camber setting.
Old Sep 6, 2010 | 11:57 AM
alex_b's Avatar
WOW PERFECT!!!im going to go with +12 front +0 Rear for sure now. The 12+ in the front look perfect just that i will most likely be running a streched like a 225 front, and 255 Rears. Thank for all your help
Old Sep 6, 2010 | 01:50 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
^^ Depending on what kind of tire you get, you might want to consider stretching a 245/35 on your 10.5 rear +0.
Remember that some tires stretch true, small, and large. What tires are you going to be using?
Old Sep 6, 2010 | 07:50 PM
alex_b's Avatar
I might be going with either some really good used michellen or also some really
good used bridgestones potenzas or some new nanknags type two. Will be running 225/35/19 f and 255/35/19 rears or Mabey even 265/30/19 not sure.
Old Sep 13, 2010 | 09:49 PM
alex_b's Avatar
Hey guys I went ahead and put a deposit on + 0 all around. the wheels are on back order but surely when i get them i will put pics up.
Old Sep 13, 2010 | 09:51 PM
sweet! what finish you get?
Old Sep 13, 2010 | 09:52 PM
Glad you made the right decision
Old Sep 13, 2010 | 11:44 PM
alex_b's Avatar
Matte black. Have an ob g35.
Old Sep 13, 2010 | 11:47 PM
should have gone with WHITE so you could be a OREO!! lol jk good choice!
