17" coupe wheels over Brembo's?
Old Oct 15, 2004 | 07:05 AM
seanfenn's Avatar
I would like to use stock 17" coupe wheels with snow tires on my coupe with 18" wheels. Does this fit correctly over the Brembo's?
Old Oct 15, 2004 | 12:59 PM
bkchang79's Avatar
Re: 17" coupe wheels over Brembo's?
the sedan and coupe 17s will not fit over the brembos, but the 350z 17s fit over the brembos.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
http://www.sounddomain.com/id/bkchang79
Old Oct 18, 2004 | 10:52 AM
pezzonovante's Avatar
can anyone else confirm this?? are they the same widths as the G stock 18s? i'm also looking into this for a winter setup.
Steve
2004.5 6MT Coupe -- DG/G -- Aero -- Prem. Pkg. -- Navi -- 20% Tints
Aluminum Drilled Pedals -- Clear Corners -- Zaino -- PIAA Xtreme
Old Oct 19, 2004 | 07:38 AM
seanfenn's Avatar
Assuming the 350 Z wheels fit, are they also the correct offset so the tires do not rub or appear too far inboard of the fenders?
Old Oct 19, 2004 | 10:17 AM
lowrider's Avatar
I can't confirm whether they will fit over the Brembos or not, but I can confirm that the offsets are correct for the "G" and the width is also the same as the "G" 17s. 7.5" front and 8.0" rear. IMO, they are also the better looking of the two wheels.
Lou
Old Oct 19, 2004 | 12:17 PM
THX723's Avatar
G Kreuzer
The 17" 350Z wheels will indeed clear the Brembos ... just barely. It does share the same exact width and offset as the Coupe 17". The difference is at the spoke design, which for the Z's case is just thin enough to clear the Brembos.
Clint (THX723)
Old Oct 19, 2004 | 01:02 PM
will "just barely" cause any problems? right now this is my #1 choice for a winter wheel/tire setup.
Steve
Aluminum Drilled Pedals -- Clear Corners -- Zaino -- PIAA Xtreme White
Old Oct 19, 2004 | 01:45 PM
THX723's Avatar
G Kreuzer
Forgive me for being reluctant to tell you that's it's 110% ok, when your safety is at stake. Having said that, I have seen Brembo equipped Z/G use those 17s for track use. If in doubt, you can always run a 3mm spacer (relatively thin) ... at which point, the 17" coupe wheels will also work.
Clint (THX723)
Old Oct 19, 2004 | 02:24 PM
seanfenn's Avatar
Nice,
Thanks for the info. Any idea on where to get 3mm spacers?
Old Oct 19, 2004 | 02:26 PM
Gizmos_G35's Avatar
Tirerack for 17's
If you're looking for a cheap 17" tire/wheel combo for winter you might look at Tirerack. I just received some 17's last night from them and they cleared the Brembos just fine.
I was looking at getting 18" tires to replace the stock rubber. The package I put together, including 17" wheels and tires, was about the same price. And now, I don't have to have the rubber swapped out and can change the tires myself when the weather gets bad. Also, the 17" tires will be cheaper to replace in a few years.
I choose the cheapest wheels the ASA JH3 (nice 7 spoke that looks close to stock) and the cheapest studless Ice and Snow tire (Dunlop Graspic DS-2). The whole package, with shipping, was just under $1,000.
Tried them on last night and everything cleared.
Just a thought.
Old Oct 19, 2004 | 02:49 PM
Re: Tirerack for 17's
i was just looking at the same setup on there with the bridgestone blizzaks, around $1100, not too bad.
i was looking into the Z wheels because they are very cheap on ebay. i've seen all 4 for $200 (compared to $129 per wheel for the cheapest on tirerack). they might have minor scratches, but i don't care since it's the winter anyway.
i'm also pricing a few other ideas i had like getting winter tires for my stock 18s, then buying new 18s or 19s in the spring. i want to spend as little as possible for a winter setup, but if i can get new "summer" wheels out of it, i might spend the extra dough. not sure what i'm gonna do yet.
anyone know of any other OEM wheels that fit over the brembos since they are pretty cheap on ebay? i don't mind if it says nissan on it, but there's no way i'm getting OEM wheels that have another make's name on them.
Steve
Old Oct 21, 2004 | 01:17 PM
dmcclan's Avatar
Do you have photos of your setup? I have been trying to find better photos of the JH3's but have been unable to do so. I'm also looking at them for snow tires.
Thanks
Dan
Old Oct 21, 2004 | 02:16 PM
Gizmos_G35's Avatar
Got your PM.
Will try and post some shots this weekend.
Old Oct 24, 2004 | 05:48 PM
CrazyMike's Avatar
I think I can answer the question here. If you want stock 17" coupe rims to fit over your Brembo brakes, check out this thread:
http://www.6mt.net/forum/topic.asp?T...erms=17,brembo
Without the spacers it is about 1-2 mm clearance, now it is closer to 4-5 mm which is plenty. I got my spacers at www.ezaccessory.com. I'm going to use this setup for this winter, and then likely keep the rims for auto-x. I hope this helps!
Mike
Old Oct 24, 2004 | 07:37 PM
any idea how much space there is with the 350z wheels and brembos on the coupe?
Steve
G-Squad Hi-Res Gallery
