What spacer size can I used without rubbing?
Old Sep 22, 2010 | 02:37 PM
draco1020x's Avatar
I have a set of 20" axis shines on a coupe and I'm lookin into using spacers in the rear. I'm not trying to go over board, I jus want them to poke out a bit. Is it possible to do this with a wheel this size? If so what size spacer can I use without causing the the wheel to rub? I'm running 275s in the rear.
Old Sep 22, 2010 | 02:51 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Offsets?
Old Sep 22, 2010 | 02:52 PM
LightsOut's Avatar
SIETESG
offsets
wheel widhts
Old Sep 22, 2010 | 03:46 PM
draco1020x's Avatar
Fronts are 20x9 with +15 offset and Rears are 20x10 with I believe a +25 or + 20 offset
Old Sep 22, 2010 | 05:39 PM
XiN's Avatar
XiN
Itasha Coupe
10mm in the front and a 15mm or 20mm in the rear.
Old Sep 22, 2010 | 05:51 PM
LightsOut's Avatar
SIETESG
are your rear fenders rolled?
Old Sep 22, 2010 | 07:50 PM
draco1020x's Avatar
No but I figure they'll have to be once I run the spacers
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
