5Zigen20" Hyper 5Zr's
Old Apr 23, 2003 | 12:15 PM
  #31
djgcue's Avatar
Re: 5Zigen20" Hyper 5Zr's
Actually in live in So. Cali where the CHP thrive to give fix it tickets for tinted windows. Good thing my G35 is a garage biatch and never moves.
6MT; Desert Platinum; Nav; premium; performance
Old May 1, 2003 | 01:58 AM
  #32
Gwhzz's Avatar
dj,
bro that is the tightest G coupe I've seen so far.
can't believe those are 20s...whew...sickness!!!
the G's come with coil overs in the front, did you
manually lower the front by adjusting the coil overs?
or did you just switch to Eibach springs?
do you know how hard it would be to lower the front by just using the coil overs?..i noticed no one has used this method yet.
also, did you have to use spacers at all for your wheels?
how much are a set of those?
i'm debating right now whether to go with 19 in front and 20 in back. i'm just afraid 20s all around would be too big and affect performance too much..what are your thoughts?
Old May 1, 2003 | 02:21 AM
  #33
djgcue's Avatar
Gwhzz thanks for the compliments!
The stock front springs are coilovers, however, they are not height adjustable. In order to adjust the height you need a damper set up like those found on the Tein system. I'm actually getting those test fitted to my car right now and should have my car back by Thursday night. So if you want an inexpensive method of lowering you could purchase Eibach springs but this wears your stock shocks out quicker too.
I did not have to use spacers, so long as you get the correct offset there shouldn't be any need for spacers. 20's will definitely affect performance. However, I just don't feel 19's fill the wheel gaps enough. I got the 5ZR's as a sponsorship, so I'm not sure how much they retail.
Old May 8, 2003 | 11:29 AM
  #34
Gwhzz's Avatar
DJ,
Your offsets that you posted: +25 on the front and +38 on the back. would this be true of all 20 " rims or just on the Zigens?
Old May 8, 2003 | 11:34 AM
  #35
Gwhzz's Avatar
also, i noticed you had 20x8.5 in front do you think 20x9 would be too wide?
Old May 8, 2003 | 06:22 PM
  #36
ronnie5's Avatar
wow...looks hot. definately top notch. how does it ride with the 20's?
Old May 8, 2003 | 07:48 PM
  #37
djgcue's Avatar
20x9 will fit in the front, I was originally getting that size with the Axis Mod Seven.
The ride is okay with the 20's it has more rode noise on the freeway, however.
Old Sep 27, 2003 | 12:16 PM
  #38
R1cky's Avatar
so u got sponsor by 5Zigen? U didnt pay anything for the wheel?
Old Sep 27, 2003 | 12:58 PM
  #39
ncozby's Avatar
Definitely one of the nicest coupes I've seen, congrats.
<font color=blue>2003 G35 BS Sedan AT - St. Louis, MO
Premium, Winter, Xenon
35% Tint All Around - Clear Side Markers
MB Quart / Eclipse Stereo System
PIAA Extreme Whites - K&N Drop-In</font color=blue>
AJC128
Nov 1, 2015 11:55 AM
the93owner
19 Inch
Sep 23, 2015 03:03 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
djgcue
West
Nov 19, 2003 10:35 PM
Tybrey
Nov 6, 2003 03:55 AM
