Will 245/45-17 work on a 03 Sedan
Old Oct 24, 2010 | 01:43 PM
G35nNJ's Avatar
Time for some new shoes and I'm thinking of going with 245/45-17's...will they fit on the stock 17x7 rim?
Old Oct 24, 2010 | 01:57 PM
thescreensavers's Avatar
Mr.202?
245s wont fit on a 7inch rim, it will fit a 7.5inch rim which is the smallest rim a 245 will fit on.
Old Oct 24, 2010 | 02:11 PM
G35nNJ's Avatar
So the widest I could go on a 7" rim would be 225 or 235?
Old Oct 24, 2010 | 02:16 PM
Mr.202?
Go on tire rack choose a size that you want, select a tire and click the spec tab it will show you the rim width range needed for the tire.
Before you go wild with different sizes you also need to make sure they are not much smaller or bigger the OEM
http://www.miata.net/garage/tirecalc.html
Old Oct 24, 2010 | 02:31 PM
drkay's Avatar
i have 235/50/17s on my stock rims all around. . .thats as big as you can go
Old Oct 24, 2010 | 02:39 PM
G35nNJ's Avatar
Just went out and took a look...guess I have to stick with 235/50/17 for now...Thanks guys!
Old Oct 24, 2010 | 06:59 PM
Infiniti Chica's Avatar
I have 235/55/17 on OEM rims (5 years now), so you can also go taller with no scraping even with other adults riding. It fills the well up a bit too. The 215's were too small for my taste.
Old Oct 29, 2010 | 06:37 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Would the 235/50/17 or 235/55/17 also work for the 06 sedan? My guess is yes, but I could be wrong. I currently have 215/55/17 right now and I roll 3-4 mph underneath what my speedometer says. I also think it looks small on the car, I really feel like the tire doesn't fill in the well.
joedaddy1
Jul 28, 2015 02:58 PM
Rehman2009
Jul 27, 2015 03:23 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
hrdwirk1
Jul 14, 2015 05:46 PM
