help on wheels?
Old Oct 20, 2004 | 03:29 PM
barata's Avatar
help on wheels?
Hi guys,
I'm ordering a 19x9 (F) and 19x10 (R) wheels with a 245/35/19 and 275/30/19 tires. Btw, it's for my g35 sedan. Do you guys think it fits my car perfectly or do I need to roll the fender?
Thanx in advance guys.
Old Oct 20, 2004 | 04:17 PM
iLLG35's Avatar
NY G-Squad G Race Driver
Re: help on wheels?
Well i have the same exact setup as you, except i am running 19x9.5 with 275/30-19" tires and im dropped with springs..... I didnt need to modify anything at all, it isnt rubbing even with 4 people in the car either, its close but not rubbing still and no fitment issues or anything! I think you could get away with it or you might need very minor modification to it, whats the offset? That could also determine wether or not it will rub, mines a +38! Martin
Martin
2003.5 BS G35
Nismo Aero/Sport Package
0-60 5.4 - 1/4 Mile 14.16 *GTech* and on 19's!!
Old Oct 21, 2004 | 02:34 PM
bzabodyn's Avatar
Re: help on wheels?
8.5 front and 9.5 rear is about as wide as you're going to be able to run on the sedan...there's just not the clearance up front for wider... regardless, when going staggered, you are going to need to go with around a +40 offset front and rear to be able to clear the fender/suspension pieces...
If you wanted to go with wider wheels, you should have bought the coupe...
2003.5 BS coupe 5AT
Clear Corners, Alum. Pedals, Pro-1 Intake, Resonated Test Pipes, UR Pulley, CF Engine Cover, GReddy EVO II, Kinetix Plenum, Hotchkis Sways, Pro-1 Headers
Old Oct 21, 2004 | 02:49 PM
iLLG35's Avatar
Re: help on wheels?
Bza's right, but for a 10" wide wheel, you could just roll the fender in the rear if its rubbing, theres always that chance it will go on without a problem, try it out!
Martin
2003.5 BS G35
Old Nov 8, 2004 | 01:34 PM
G35Lin's Avatar
Multi-Spoked Mod
Re: help on wheels?
i agree with most of these guys. 8.5 and 9.5 seem the way to go. I although think that you can run different offsets for front and rear. Someone said you ahve to run 40s all the way around but i dont think so. I am running +35F and +45 rear. i seem to be doing fine!!
Also my rims are up for sale if you are interested in them:
Click here for the specs and pictures
Ed
2003 Transport V35SKYLINE. Team Transport! www.teamtransport.org
Old Nov 22, 2004 | 12:54 PM
Built2Shred's Avatar
Re: help on wheels?
I personaly wouldnt go wider then 19x8.5 (front) and 19x9.5 (rear), unless you dont mind rolling your fenders..
2003.5 G35 Sedan White/6MT
Nismo Type S Suspension / Nismo Sway Bars
19" OZ Rims / Stillen Front/Rear Camber Kit / Z Tube
Stillen Big-Airflow Intake / Stillen Catback Exhaust
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
